Which throttle body and intake manifold should I go with?
I am building a N/A B16 for my 91 HB and was wondering on which throttle body and intake manifold to go with. I was thinking of useing the skunk intake manifold and the STR throttle body. If you have any advice or have had problems with these please let me know.
im not a big vtec man so i have to ask.. what is the advantage to using a ITR manifold over aftermarket and also whats kind of gains are proven by using ITR cams in a b16? sorry to jack your thread but im curious.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by NitrousDreamz »</TD></TR><TR><TD CLASS="quote">im not a big vtec man so i have to ask.. what is the advantage to using a ITR manifold over aftermarket and also whats kind of gains are proven by using ITR cams in a b16? sorry to jack your thread but im curious.</TD></TR></TABLE>
The ITR had a well ported intake manifold that was port matched to it's Throttle body allowing for a greater flow over a stock b16. The ITR Camshafts have MUCH more agressive vtec lobes than the b16 camshafts allowing for greater power up top, also allowing one to rev higher.
All your suggestions were good but i should have filled you in more. The head was built with skunk stage 2 cams with oversised vales springs and retainers. and i bored the block and am runing 12 to 1 comp with a 10 rpm redline. so now my question is do you think i should use the itr or ctr parts or go with what i origanaly suggested?
crazyguy
Jan 7, 2008 07:17 PM
timisyourfriend
Dec 12, 2006 11:35 PM
RedRex8
May 28, 2003 09:52 PM
FusionEg6
Apr 21, 2003 08:22 PM
As for the cams if you want to stay oem get the CTR's.
