header install, can one take old header out as one peice?
Old May 31, 2003 | 12:43 PM
subtleluck's Avatar
Default header install, can one take old header out as one peice?
just curious if i could take the old header out as a one peice or do i have to remove it as a two piece, the bolts that attach the two pieces together are deep inside the body, and rusted as hell, so i rather not bother with them?
i do have to unscrew the old header from the "frame", that is it attaches to the car where the two pieces of the header meet, (that is other than engine block and the cat)
thanx for all the info
Old May 31, 2003 | 12:45 PM
AWDxBOOST's Avatar
Default Re: header install, can one take old header out as one peice? (subtleluck)
http://www.c-speedracing.com/h...r.php
all ull need
Old May 31, 2003 | 12:54 PM
subtleluck's Avatar
Default Re: header install, can one take old header out as one peice? (ls_teg)
the link isn't exactly in usable form, can you try posting it again?
Old May 31, 2003 | 01:20 PM
ebelp's Avatar
Yes, the manifold will come out in one piece. After you remove all the bolts that hold it on, you can maneuver it out through the bottom of the car. It's easy, trust me.
Dahl Sol
Nov 30, 2009 01:51 PM
Cornering Artist
Honda S2000
29
Mar 4, 2007 05:42 PM
prejdmlude
Nov 11, 2006 01:28 PM
iuseamsoil
Mar 9, 2004 07:47 AM
RStoR
Sep 5, 2001 06:31 AM
