put in a new horn and...
it sounds so weak. i have it all wired right, ground is fine, it's a 130db highway horn. was working for like a day (and was f*ing loud), but now sounds muted. i rechecked all the wiring and checked the fuse.....all okay.
is it possible i need a relay in there since it is drawing more power?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by fivespeedintegra »</TD></TR><TR><TD CLASS="quote">it sounds so weak. i have it all wired right, ground is fine, it's a 130db highway horn. was working for like a day (and was f*ing loud), but now sounds muted. i rechecked all the wiring and checked the fuse.....all okay.
is it possible i need a relay in there since it is drawing more power? </TD></TR></TABLE>
might be...but a lil more info would be nice
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by fivespeedintegra »</TD></TR><TR><TD CLASS="quote">what other info do you need?
ground is okay, i know it's getting power, cause it works, but sounds muted. fuse is fine. don't know what else to do...</TD></TR></TABLE>
yea i jus needed to know what else you tried....anyways im not sure as of now...i might think of somethin later
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by WundedSaint »</TD></TR><TR><TD CLASS="quote">maybe you hooked it up in reverse polarity? The horn isn't grounded through the chassis...
rmc</TD></TR></TABLE>
where should it be grounded??
i tried reversing the wires....same result.
First... Verify that your horn is not the problem. Hook up some test wires to the horn and touch them to the car battery.. If it sounds F'n loud, then its not the horn that's a problem, its a problem with your wiring or your not getting enough juice to your horn.
Take your trusty multimeter and read the voltage drop that comes across the line when you press the horn switch and see what you get.
A440Hz
Apr 4, 2016 08:32 AM
PumaFiveOh
May 30, 2006 06:24 PM
spooncivic1
May 17, 2005 08:12 AM
