LS/GSR gauge needles on EG cluster?
Old May 31, 2003 | 07:20 AM
skribblah's Avatar
Default LS/GSR gauge needles on EG cluster?
i did the ambur backlighting "mod" to my cluster, (looks VERY nice BTW, and if you dont want that ring of sickness light, as you can see in this picture then just pop off the clear parts that allow the light to shine thrugh, spray thos bitches black, and boom your set. makes mine look hellatight...) and at night my needles are somewhat very hard to see.. does anyone know if the needles are a direct swap or do they just not fit?
Old May 31, 2003 | 10:03 AM
skribblah's Avatar
Default Re: LS/GSR gauge needles on EG cluster? (skribblah)
anyone know? or at least have any guesses?
Old May 31, 2003 | 10:06 AM
Caveman74's Avatar
try making your needles yellow. Thats how my old rx-7 was
Old May 31, 2003 | 10:57 AM
skribblah's Avatar
Default Re: (Caveman74)
what i was aiming at is no matter what color they are, they just arnt that visible. i know for sure the ls/gs/rs/gsr/whatever clusters have the needles and they light up using the light from the 3 bulbs that light the whole cluster. so im going for some sort of illumination on the needles if anyone knows if the swap would work or what?
Old May 31, 2003 | 12:35 PM
skribblah's Avatar
Default Re: (skribblah)
anyone?
Old May 31, 2003 | 01:03 PM
adrian1281's Avatar
i was thinking of hooking up some leds in my cluster, replacing all the bulbs. i wonder if u can mount an led to specifically light up the needle?... ill post a how to if i do it.
Old May 31, 2003 | 01:08 PM
DumpedSi's Avatar
I wouldnt mess with your needles, typically when you do it, it ***** them up and they car at idle will be around 20mph
Old May 31, 2003 | 02:02 PM
Hybrid96EK's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by skribblah &raquo;</TD></TR><TR><TD CLASS="quote">what i was aiming at is no matter what color they are, they just arnt that visible. i know for sure the ls/gs/rs/gsr/whatever clusters have the needles and they light up using the light from the 3 bulbs that light the whole cluster. so im going for some sort of illumination on the needles if anyone knows if the swap would work or what?</TD></TR></TABLE>
The GSR needles don't "light up" like you are thinking. The color they are painted causes them to reflect some of the light, giving them the illusion that they are lit up. As stated earlier, try changing the color of your currentl needles. I would bet $100 that you wouldn't get away with a needle swap anyways without breaking at least 2 of the current ones. Even if you could get them off in one piece, good luck recalibrating the gauges.
Old May 31, 2003 | 02:59 PM
skribblah's Avatar
Default Re: (Hybrid93Eg)
so basically unless i break out the paint, im screwd?
Old May 31, 2003 | 04:37 PM
midnightdarknes5's Avatar
and even if you paint them, if I'm not mistaken I believe they are weighted. so by painting them you'll have too much wieght and then they'll be all off, therefore not really having accurate readings one any of your gauges
Kevins89notch
Jun 7, 2011 08:02 PM
WiedemannC
Honda Civic (2001 - 2005)
Oct 22, 2010 04:33 AM
CTR_B
Mar 20, 2008 09:47 AM
CL1accord
Jun 24, 2005 09:59 AM
RTW DC2R
May 23, 2004 06:20 PM
