quick question------will a F23 auto tranny work on a H23?
i'm thinking since i know a f23/f22 tranny will work in a H22 it should bolt up with a H23 right?
I'm unsure because the H23 sorta different and perhaps all the bolts may not line up with the tranny case and block.
From my knowledge it should bolt up with no problem. F & H series motors and transmissions are all interchangeable, with the only difference being the gear ratios.
don't know if this helps but i know a guy with a F23 motor and a H23 5spd tranny. bolted right up, no problems. if it works in one direction it should work the other way.
Now why you find the F23 auto tranny desireable I can't imagine....
