Which A/C bracket in '90CRX with a B17
I've read all the posts under "A/C Bracket" and I can't seem to find
a consenus. They don't make any sense.
So I'll ask again.
Which A/C bracket works with a sanden comp in a'90 CRX
with a B17?
Del sol P/N pr30?
Del sol P/N pr54?
What's the difference between the two?
HaSport Or JDM ITR?
Thanks
Modified by 4crx4me at 1:46 PM 6/1/2003
So I'll ask again.Which A/C bracket works with a sanden comp in a'90 CRX
with a B17?
Del sol P/N pr30?
Del sol P/N pr54?
HaSport Or JDM ITR?
Thanks
I don't know if the b16a1 and the b17 have the same block but if they do (I think they do), you can get an adapter from one of the companies that sell the mount kits. I believe all the JDM models had different type compressors, but don't quote me on that. I have had great luck with the Place racing bracket with the sanden compressor, but I have the place racing mounts too - YMMV. Adding the a/c back into your engine will help reduce vibrations too, an added bonus!
None of these OEM brackets will work with the OEM Sanden (or Matsushita) compressor. You need a custom bracket. Hasport makes one that works with both compressors. And Place Racing makes brackets for either compressor.
ej8slim
Sep 10, 2005 04:56 PM
