floor flex????
Old May 30, 2003 | 11:11 PM
plastik462003's Avatar
Default floor flex????
i noticed that the floor right behind my front seats moves if u push up from underneth the car and if u push from inside the car it also pushes down a bit i do not see any signs of rust from underneth or on the inside?? my question is..... is this normal...... or is it rusted under all the tar.... or is the metal just that thin in that spot???? any info will help thanks
it would be helpful if someone could check their hatchback and see if your car does the samething
Old May 31, 2003 | 06:47 AM
89civicdx's Avatar
Default Re: floor flex???? (plastik462003)
mine does that...my guess the metal is thin.
Old May 31, 2003 | 06:58 AM
bfrank81's Avatar
Default Re: floor flex???? (89civicdx)
Mine is solid. I would be a little nervous if it moved cause that sounds a little dangerous.
Old May 31, 2003 | 02:26 PM
Default Re: floor flex???? (bfrank81)
bump i need more info please help
Modified by plastik462003 at 11:48 PM 5/31/2003
Old May 31, 2003 | 07:49 PM
bump again wtf
Old May 31, 2003 | 08:43 PM
baruba's Avatar
well i remember in both the 88 sundance i grew up in when my dad would drive over hard as ice snow that looked like itll rip the exhaust i could SEE the floor in teh back bent in! i have driven in fresh snow with teh rex i could feel it move a bit
the body rails are stiff but the floorpans just thin metal.
Old Jun 1, 2003 | 01:20 AM
Default Re: floor flex???? (baruba)
bump for the last time
ShreqBoi
Dec 28, 2009 11:42 AM
turnsignalandy
Apr 28, 2007 11:20 AM
SpoonyDC5
May 7, 2006 07:44 AM
