How much would it cost to switch from automatic to manual?
What car is this? My 97 hatch started off as an automatic but now it sports a standard 5-spd with a B18C motor. It's a lot cheaper to do if you change it while you are swapping the motor. Otherwise, it's not really worth it...For Civics, I'd say a auto-5spd swap should cost around 1000-1500. You can just source all the 5spd parts on your own(expect around 5-700 for the parts) and just pay someone labor to do it for you. The 6g civics are pretty much straight forward in terms of swapping in a 5spd into an auto car. The 5g Civics I believe you will need to reweld a tranny mount in a different location...
It is a 2000 civic HB. I plan on doing a motor swap soon and i wanted to know how much it would be to switch it to 5 speed. 1000-1500?? dang thats alot... i thought it would be alot cheaper cuz someone told me that it would be around 500.
[Modified by LiLxKiMcHeE, 6:33 PM 7/16/2001]
The 5spd parts alone will run you close to 500 or more. If you plan on doing a motor swap soon, just wait and do it all at once. It's cheaper that way because everything is out of the car.
So lets say i swap in a b16a2... what do you think the total estimate would be to buy the motor, drop in the motor, and switch to 5 speed? about 4Gz?
I don't know about 4,000 bucks, that's a lot for a B16A, I got my 97 B18C installed, my car converted to manual...etc, etc, for 3200.
Doesnt the b18c alone cost about $3000?? Wow... How did you get everything done for so cheap??
But even if you had bought the parts yourself how in the world did you get it ALL done for $3200?? Like i said... isnt the motor itself about $3000?? Where did you buy your motor? Most of my friends who have done a b18c swap spent around $4500. And thats without swapping auto to manual. You must of gotten hooked up or something.
I think im going to go buy the parts soon. Do you know exactly which parts i need to buy? If you do could you list them for me? Thanks man...
travbrack
Aug 3, 2010 03:17 PM
joshcivic00
Jul 11, 2005 12:27 PM
