TSX engine swap
Old May 30, 2003 | 05:52 PM
RSXplaya's Avatar
Default TSX swap
sup people, i was just wondering if any of u know if the TSX engine K24? i dont know the tsx engine code exactly.. but anyway, TSX with 5 speed sportsshift tiptronic transmission can this be possible to bolt onto the DC5 base RSX with a 5 speed sportshift tranny???u know with all the works TSX ECU, TRANNY , ENGINE , ETC..
i just wanna know if this can be done or not ?
thanks
Playa
Old May 30, 2003 | 06:09 PM
No-Gi's Avatar
Default Re: TSX swap (RSXplaya)
Do you have a base RSX?
Old May 30, 2003 | 06:38 PM
RSXplaya's Avatar
yes
02 RSX base auto
Old May 30, 2003 | 08:14 PM
Westrock2000's Avatar
Default Re: (RSXplaya)
Why didn't they put one of the more powerfull V6's in this car? Like a step down to the CL-Type S. Seems like a big car for NA 4 cylinder. Now your right this engine in a Type S RSX would be much better suited.
Old May 30, 2003 | 08:58 PM
David S. Wallens's Avatar
Default Re: (Westrock2000)
Honda says the four-cylinder engine was chosen for the TSX due to its lighter weight. Honestly, it's a cool car with nice balance.
Old May 30, 2003 | 11:57 PM
SlammedBlueEM2's Avatar
Default Re: (David S. Wallens)
I can't recall any JDM Accord bearing a V6 engine. Seems like the U.S. market Accord is blessed exclusively with those engines unless those engines came from another JDM Honda perhaps? Can anyone verify that for me?
Old May 31, 2003 | 06:02 AM
RSXplaya's Avatar
will this swap be POSSIBLE to the RSX??????
lets not be way out of topic here
Old May 31, 2003 | 06:37 AM
hired gun's Avatar
I am pretty sure you can swap the motor in there. but how are you going to get around the DBW(drive by wire) throttle??
Old May 31, 2003 | 10:25 PM
7thGenAccord's Avatar
if you got money anything is possible
Old May 31, 2003 | 10:29 PM
f1nal zeros's Avatar
People have done the k24 bottom with the type S head, but I do not know if anyone has done the base motor and swapped the complete k24 motor,tranny, and ecu. You can look around and see what you can find out. For more information you might want to check out http://www.clubrsx.com for more information on this. The RSX has a forum for base owners as well. Good luck.
Old Jun 3, 2003 | 12:14 PM
00MRSi's Avatar
Default Re: (f1nal zeros)
I would think it could be done. Not sure. A k24 bottom end with a type S head is very similar to a TSX motor if I'm not mistaken. Ask Jack/B18CXr he would definitely know..
Old Jun 4, 2003 | 07:45 PM
.Chris.'s Avatar
Default Re: (00MRSi)
As for the drive by wire throttle:
I don't know exactly but I bet you could rig it up fairly easily. You would likely need the pedal linkage and the harness for it. You would also need a TSX ECU I imagine, or perhaps a standalone like AEM EMS.
Old Jun 6, 2003 | 07:15 PM
HiRevn's Avatar
Default Re: (Black204GSR)
Isn't the K24 in the CRV too? If so, it would probably be easier to source one of those.
Old Jun 9, 2003 | 09:20 PM
boostedhonda's Avatar
I just saw this car the other day...it is very sweet looking!
Old Jun 10, 2003 | 07:05 AM
TsunamiZC's Avatar
Default Re: (George Knighton)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by George Knighton &raquo;</TD></TR><TR><TD CLASS="quote">
The TSX K24 is 200 HP and 170 # of torque. It can easily be developed all the way up to 280 NA very easily.
The car just wasn't designed for a heavy motor.
It's a lightweight, fairly powerful car that goes back to the wonderful double wishbone suspension that we all loved in the ITR and other wonderful Hondas.
It's one of those "You either get it, or you don't" situations, I guess.
If you want a V6, the Accord costs about the same as the TSX.</TD></TR></TABLE>
judging by the dyno, the 200HP rating seems to be pretty much spot-on (makes about the same 170 at the wheels that an RSX-S does).
but the 166ft-lbs of torque on the TSX apparently is WAY underrated.
this particular TSX appears to be making more like 175-180ft-lbs. (153 at the wheels).
if the pic doesnt work ...copy and paste it into your browser
http://sohc.vtec.net/news_file...k.gif
Alex Alvarado
May 24, 2019 08:50 PM
chippychops
25
Apr 12, 2004 01:55 PM
fastludeh22
May 29, 2002 08:46 AM
Screamer
Apr 24, 2002 12:19 PM
SuspectProduct
Jul 19, 2001 10:10 PM
