Will a 90-93 integra cluster......
Old May 30, 2003 | 05:10 PM
Turbo Powa's Avatar
Default Will a 90-93 integra cluster......
Will a 90-93 integra cluster just plug and play or do I need to re-wire it? Anyone have any write ups or websites? Anyinfo would be great. TIA! pics too please
Old May 30, 2003 | 06:46 PM
bryant's Avatar
Default Re: Will a 90-93 integra cluster...... (Panda EK)
Most likley its not gonig to plug and play. A bit of wiring is in need, I thaught I have seen a couple ppl do it, but I dont remember any sites for write up on it.
Old May 30, 2003 | 06:51 PM
Turbo Powa's Avatar
Default Re: Will a 90-93 integra cluster...... (Bryant)
thanks..... anyone else?
Old May 30, 2003 | 08:20 PM
Kyo Babic's Avatar
yes you do have to rewire some stuff,
and trim away some of the dash to make it fit, but it does look quite cool when its done i got one in my and i likes it alot.
this how i did it in my 91 civic.
this is how you gots to wire it up(just like a teggy)
large clip
green/blue l blue/red l vacant l blue l vancant l yellow/green l black l yellow l green/orange l black/yellow l blue/white l yellow/red
Small clip
yellow/red l green/red l green/black l vancant l yellow/white l yellow/red l red l vancant l red/black l green/yellow
you have to extend some of the wires to make them fit to the other clips, but its all good.
Old May 31, 2003 | 01:19 AM
89dxhunchback's Avatar
Default Re: Will a 90-93 integra cluster...... (Kyo Babic)
So a 90-93 cluster fits right in pretty much ?... Minus the wiring of course....
Old May 31, 2003 | 09:37 AM
Turbo Powa's Avatar
Default Re: Will a 90-93 integra cluster...... (89dxhunchback)
do I need the integra clips or can I use the crx ones?
Old May 31, 2003 | 11:48 AM
chief_rucka's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Kyo Babic &raquo;</TD></TR><TR><TD CLASS="quote">yes you do have to rewire some stuff,
large clip
Small clip
you have to extend some of the wires to make them fit to the other clips, but its all good.</TD></TR></TABLE>
do you have any pics of it? i have a 90-93 cluster just lying around.
Old May 31, 2003 | 11:50 AM
Turbo Powa's Avatar
Default Re: Will a 90-93 integra cluster...... (E30rider)
that would nice.....
Old May 31, 2003 | 06:43 PM
Kyo Babic's Avatar
oh yeah i forgot, you do need to teggy clips, and trim away some of the dash to make the cluster fit, i post some pics once i get my digi back.
Old Jun 9, 2003 | 08:36 PM
Kyo Babic's Avatar
here are some pics sorry taking so long
Old Jun 9, 2003 | 08:38 PM
Kyo Babic's Avatar
it mostly fits the cover kinda blocks the gas guage alittle but no big deal. its a working cluster with a tach
Old Jun 12, 2003 | 11:30 PM
buzz_worthy321's Avatar
what about the mph gauge is it plug and play...
Old Jun 12, 2003 | 11:37 PM
do u have to have a electric mph sensor
Old Jun 13, 2003 | 06:08 AM
b16_madman's Avatar
Default Re: Will a 90-93 integra cluster...... (buzz_worthy321)
if its easy i say go for this....
it's on ebay if you were wondering.
Old Jun 13, 2003 | 11:25 AM
Kyo Babic's Avatar
the speedo is plug n play everything works all you need is the integra clips then just wire it up as if its an integra....and some triming of the dash is need to make it fit
Old Jun 17, 2003 | 05:43 PM
thks i got mine in and working i just have to trim the dash. do u know how much i need to trim away and where
Old Jun 17, 2003 | 07:24 PM
Francois's Avatar
The picture are on a 88-89....do you guy's think that would be different(the way I see each corners of the cluster) on a 90-91???
Old Jun 18, 2003 | 10:00 AM
Kyo Babic's Avatar
Default Re: Will a 90-93 integra cluster...... (Francois)
that picture is in my 91 civic not a 88-89
Old Jun 28, 2003 | 11:44 PM
Si2See's Avatar
does this work the same for an eg hatch? or does the speedo not work
Old Jun 28, 2003 | 11:48 PM
Built B16A's Avatar
From: hittin corners so hard you can taste my rims..
EG Hatch's are electric VSS... pulse.. not speedo cable.. and just wondering.. why would you use the 88-91 cluster hood, in a 91? i would think the newer style hood would fit better?
Old Jun 29, 2003 | 07:18 AM
dohc vtec's Avatar
Did you use the Integra cover that goes over the cluster? Because i've got a GSR cluster and I dont see how the cluster will fit in the EFs cover.
Old Jun 29, 2003 | 07:20 AM
dohc vtec's Avatar
Default Re: Will a 90-93 integra cluster...... (dohc vtec)
Also what did you screw the cluster into the factory holes dont line up with the Integra holes.
Old Jun 29, 2003 | 11:45 AM
Built B16A's Avatar
theres a post floating around here.. a GSR cluster in a EF chassis.. it can be done.. but it was on a 90 (round hood) now, the 88-91.. i can't see that happeneing.. look at the older clusters, they're almost reqtangular.. the new clusters start to oval at the top.. thats why i can't see how you would put the 88-89 hood on that cluster.. but whatever works i guess.
bakoCRX
Jul 16, 2009 07:25 AM
itr1235
Mar 16, 2006 01:52 PM
WWDTrackRacer
Jan 11, 2006 07:08 PM
HatchBox
Nov 3, 2004 06:41 AM
Fuster_Cluck
Apr 22, 2003 08:56 PM
