Crank pulley missing small chunk?
Old May 30, 2003 | 04:25 PM
NateTEG95's Avatar
Default Crank pulley missing small chunk?
I just removed my crank pulley to replace my water pump. I noticed a 2cm chunk missing from the pulley around the outer edge. Will this cause my pulley to be out of balance and mess up my oil pump?
Thanks
Old May 30, 2003 | 04:40 PM
TurboBumblBee's Avatar
Default Re: Crank pulley missing small chunk? (NateTEG95)
yes you need to get that "key" it locks the crank pulley in place, with out it the pulley wont do **** for charging your alternator.. it wont mess up the oil pump.. the key costs less than 5 bux from honda
Old May 30, 2003 | 04:46 PM
IN VTEC's Avatar
I wouldn't be real concerned about it being out of balance. The accessory belts put a greater intensity and variety of forces on the crank pulley than a 2cm^2 missing chunk would.
I'd be more worried about a belt falling out of track or a warped pulley from the missing chunk.
Old May 30, 2003 | 05:13 PM
PatrickGSR94's Avatar
Community Builder
Community Influencer
Active Streak: 60 Days
I would still replace the pulley. It also serves as the harmonic balancer for the crank, and if it's out of balance who knows what it could do to your crank bearings.
Old May 30, 2003 | 09:24 PM
Default Re: Crank pulley missing small chunk? (Hybrid95CivicEX)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Hybrid95CivicEX &raquo;</TD></TR><TR><TD CLASS="quote">yes you need to get that "key" it locks the crank pulley in place, with out it the pulley wont do **** for charging your alternator.. it wont mess up the oil pump.. the key costs less than 5 bux from honda</TD></TR></TABLE>
oh ****.. i read that post fucked up earlier.. disregard that post.. mine has a little piece broken off of it from when i put the motor in and it hit the subframe.. i dont htink it will make a big deal
civikdude
Feb 13, 2009 02:17 PM
bow tie
Oct 17, 2008 01:18 PM
DARKTEG_
13
Aug 14, 2006 02:24 PM
twistedbydezign
Sep 24, 2005 02:10 PM
