wiring for b16a swap?
i put a b16a in a 91 crx si, im am using the stuck harness of the original motor that was in the car, on the b16a. i also have a ecu harness that i purchased off from hasport.com. can i use both of these together or am i creating a double negative.
what is the difference, this is what i purchased you might have to scroll down a little. http://www.hasport.com/store/index.html. its the wiring subharness for the VTEC engine. i just want to know if i can you use the stock harness of the original motor on the b16a with this harness from hasport or am i creating a double negative.
RB_EJ8
11
Aug 26, 2009 09:29 PM
