is hasport the only place that makes mounts to use cable tranny on the eg?
is hasport the only place that makes mounts to use cable tranny on the eg? i was just wondering. if i get a b16 with a cable tranny is there a cheaper route to go other then hasport for the mounts to make this work?
what direction would u take?
Been out for a few years by HCP. In one of our shop cars for almost 2 years now (YS1 GSR cable tranny on a B18B motor) and I've taken it to the track and it holds up just fine when launching on street tires. NEVER once has there ever been the dead pedal feel. PM or email me for more details if interested.
Guest
Posts: n/a
HondaTunning magazine(this month) has a how to on d16 and they show the company that helped them with the cable>hydro swap kit. they also have a hydro>cable kit out too. go to the mag store and just take a look it was easy read .15min tops
it seems like at jdm **** they only have the conversion mount for the tranny and not all the mounts needed to put the b16 in the eg
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mugensport9 »</TD></TR><TR><TD CLASS="quote">it seems like at jdm **** they only have the conversion mount for the tranny and not all the mounts needed to put the b16 in the eg</TD></TR></TABLE>
Because all that you really need is the passenger side mount. You can use stock Civic or Integra mounts & brackets on the driver side and on the rear of the transmission and rear crossmember, but unless you want to spend more for all complete replacement mounts, the passenger side is the only one that is really needed to make a cable tranny work in a hydro chassis.
so in order to swap my b16a (cable) into an eg all i need is one mount? the one for the tranny conversion?
i have some questions also. say in a few months i buy a buy a b18c short block to add displacment. do i need to get a hydpo tranny? or can i keep this one? do i also need a new mount?
i am not too familiar on how this works. please let me know
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mugensport9 »</TD></TR><TR><TD CLASS="quote">so in order to swap my b16a (cable) into an eg all i need is one mount? the one for the tranny conversion?
i am not too familiar on how this works. please let me know</TD></TR></TABLE>
You can still use the same tranny.
With the exception of the B20A, blocks all the B-series blocks have the same transmision bolt holes, and driver-side bracket holes. This makes them totally interchangeable eith each other.
brian g
brian g
B18 CYA
Mar 24, 2006 03:23 PM
