VTEC Controller +Turbo ??
Hi,
My friend has just finished installing a drag gen 3 onto his 96 spec JDM ITR.
He was previously using a Data System VTC82x.
Should he continue using this vtec controller or is it better not to change the vtec crossover point when running a turbo?
Thanking you,
Eric
Thanking you,
Eric
If you make more power and all with changing the VTEC point then change it.
I am not sure what the"Data System VTC82x" is, but a hondata with boost control is probably the best bet to go.
you will probably get e better response in the Forced Induction forum
heres mine....its okay...don't really use it much any more...but its a good one touch system...I use it to disengage my vtec sometimes to troubleshoot.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by MugenFG360 »</TD></TR><TR><TD CLASS="quote">320km/45L tank?</TD></TR></TABLE>
You kidding?!?! I'd be lucky to hit 200km nowadays!! damn turbo makes the engine drink gas!!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by MiraiZ »</TD></TR><TR><TD CLASS="quote">
You kidding?!?! I'd be lucky to hit 200km nowadays!! damn turbo makes the engine drink gas!!</TD></TR></TABLE>
you sir need tuning.
On 900cc injectors im seeing about 220mi/350km to each tankof gas.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sgT »</TD></TR><TR><TD CLASS="quote">
On 900cc injectors im seeing about 220mi/350km to each tankof gas.</TD></TR></TABLE>
yup...see sig
yup...see sig
There is also that new Greddy Profec-e which is a boost controller, and if I'm not mistaken also has a Vtec controller....and a whole slew of other cool options as well....if you're not looking to spend anymore money on fuel management, it's a good way to go, just keep in mind that it won't do your fuel maps and timing, you'll still need to retain your current fuel controller....
Good luck,
Aj
Good luck,
Aj
