88-91 Civic Ex 4dr questions.
Old May 30, 2003 | 06:25 AM
Todd00's Avatar
I said I don't want a title!
Default 88-91 Civic Ex 4dr questions.
I know this car can be had with a 5-speed, correct? If so, did the motor/tranny or anything else differ from the D16A6 in the Si? I think the ECU was not a PM6, correct?
Just looking for a little info on the 88-91 4-door Ex (Although they were only made in 90-91 I think). I might make a project car out of one.
Old May 30, 2003 | 06:31 AM
dingusjt's Avatar
Default Re: 88-91 Civic Ex 4dr questions. (Todd00)
Yeah well the EX's setup is identical to an Si....and as far as the ecu, i'm really not sure but i actually think its using the Si ecu as well....it just makes sense being that the ECU is for the engine not for the car.
Old May 30, 2003 | 07:18 AM
Ef Whore's Avatar
Default Re: 88-91 Civic Ex 4dr questions. (dingusjt)
The same thing, but I think that the EX tranny's 5th gear is a little lower for highway speeds, being it is a four door. Not sure though... Someone else back this up?
Old May 30, 2003 | 09:49 AM
blah13's Avatar
Default Re: 88-91 Civic Ex 4dr questions. (Ef *****)
I have a 90 EX and yes they come in manual, only made in 90-91, it has the d16a6 motor with the PM6 ecu. I've heard the only ecu diff is with the auto EX vs the auto crx Si's, thought its only what I've heard.
Old May 30, 2003 | 11:01 AM
eraser's Avatar
EX Foh Doh
basically an LX model with an SI engine setup...yes it was available in at and mt
mt used pm6
at used ps9
EX models had a nicer interior and bigger brakes...and despite what your mama told u or what u may think it did not come with a sunroof standard.....
they came with bling bling hub caps too
Old May 30, 2003 | 11:21 AM
Davep's Avatar
Default Re: 88-91 Civic Ex 4dr questions. (eraser)
The transmission has a 4.0x FD instead of the Si 4.25.
Old May 30, 2003 | 11:37 AM
Todd00's Avatar
Really--no sunroof on the Ex. That's interesting. What was the curb weight for a 90-91 Ex 4DR without the roof?
I thought the FD was different on the Ex, but I wasn't sure. That should be easy to fix with the Si tranny though.
Old May 30, 2003 | 02:13 PM
4drEF's Avatar
Keyboard Humorist
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by eraser &raquo;</TD></TR><TR><TD CLASS="quote">...and despite what your mama told u or what u may think it did not come with a sunroof standard.....</TD></TR></TABLE>
It didn't have rear disc breaks EVER either. Sunroof was a dealer option - I have seen them on DX's.
Old May 30, 2003 | 03:20 PM
Charlie Moua's Avatar
Default Re: 88-91 Civic Ex 4dr questions. (4drEF)
i would soooo want to get another EF. trying to find a nice ef ex is way freaken harder thank finding an EG si....
Old Jul 10, 2003 | 05:47 PM
bryant's Avatar
Default Re: 88-91 Civic Ex 4dr questions. (Charlie Moua)
That for sure is. I just found one today on a lot (91 EX). Clean too. I am so excited, new old cars rock.
Old Jul 11, 2003 | 12:28 PM
Ruby Civic's Avatar
Default Re: 88-91 Civic Ex 4dr questions. (Bryant)
i have a 91 ex 5 sp. since new with 160k and an unspecified hybrid motor in it after several other motors...i love this car!
weight was originally listed at 2368 without sunroof which was a dealer installed option that can leak after a couple of years...
ecu and tranny is essentially si. with a b16 motor in it it weighed &gt;2570 with me in it (200 lbs) and some 50 lbs. of weight taken out of body
Old Jul 11, 2003 | 12:55 PM
Brandon Clifton's Avatar
I have an 88 ED3 (4dr). As far as "project car," they are almost as limitless as an EG. Mine has:
KYB AGX 4-way struts front
KYB AGX GR2 non-adjust rear
APC coilovers (lowered 3")
Brake conversion from a 1999 'Teg LS w/ porterfield R4 pads
-the brake conversion gave me ~3.5* of pos camber, which required the 3" of lowering to correct
14x6 Prelude steelies w/ Yoko AVS ES100 tires (195/60R14)
Si longblock and tranny swap (D16 block w/ DPFI)
2.5" exhaust
It handles pretty nicely and the curb weight on the title is 1973 lbs.
I have since stripped all A/C components
oldskoolDA6
10
Dec 17, 2008 10:55 AM
sony224422
Jan 4, 2008 08:23 PM
jdeemseerx
Feb 28, 2007 09:35 AM
Agent_STFU
11
Aug 24, 2005 02:45 PM
Charlie Moua
Jun 23, 2002 09:37 AM
