Lower control arms
Old May 30, 2003 | 04:49 AM
Hate's Avatar
Default Lower control arms
ive heard that 88-91 crx's and itr's share the same rear LCA's. was hoping some of you R owners could confirm or deny this. any help would be great. thanks
Old May 30, 2003 | 04:53 AM
HondaRcB's Avatar
Default Re: Lower control arms (Hate)
I've delt with both LCAs, and when installing ITR shocks on my 90 Civic Wagon with 88 CRX LCAs, I had to grind down where the bottom of the shock goes through the LCA, because the CRX LCA is a little bit narrower then that of the ITR LCA. Hope this helps.
Old May 30, 2003 | 06:38 AM
Asahi's Avatar
Default Re: Lower control arms (HondaRcB)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by HondaRcB &raquo;</TD></TR><TR><TD CLASS="quote">I've delt with both LCAs, and when installing ITR shocks on my 90 Civic Wagon with 88 CRX LCAs, I had to grind down where the bottom of the shock goes through the LCA, because the CRX LCA is a little bit narrower then that of the ITR LCA. Hope this helps.</TD></TR></TABLE>
This is correct.
Old May 30, 2003 | 07:03 AM
Hate's Avatar
Default Re: Lower control arms (Asahi)
ok cool...thanks alot for your help
db8db8db8
Oct 16, 2009 04:35 PM
DB8
Apr 13, 2004 10:44 PM
JrCRXHF
Dec 17, 2003 05:03 PM
rasta420
Oct 24, 2002 10:18 PM
Trinity
10
Nov 12, 2001 05:20 AM
