What heads will fit on a D15B2 block?
I'm switching the Topic from "What heads will fit on a D15B2 block?" so..... Lets continue, I just wanna double check this... Text for the picture is on top so theres no confusion
Notice all the little unused/strange holes on the headgaskets.
A. A hole thats just out there, no hole in the head there but there seems to be one on the headgasket there.
B. Just alot of little holes outside of where the head was resurfaced. Not touching between the head and the block, just out there.
C. Two holes where it seems there should just be one larger one.
Theres a Lip around the inside of the gasket
Less of a lip but, just to be on the safe side
Yeah yeah yeah, I'm also hypersensitive, so sue me. Just double checking! Thanks!
Modified by KooK at 1:21 AM 5/30/2003
Modified by KooK at 1:22 AM 5/30/2003
what head is that and what gasket... other than that i wouldn't worry. the exhust mani gasket that has the lip is a good one but you don't need the lip in there just for extra sealing. but will cause a obstruction.... from the head pic all i can say is "C" is where your oil jet would be on the d15 block..... other than that i can't remember and it shouldn't matter that those extra holes are there..... but then again..... stoner moment.
