Video of my mis-shift
Old Jul 15, 2001 | 04:45 PM
xjohnx's Avatar
Default Video of my mis-shift
http://www.locashracing.com/xjohnx/uh-oh.mpg
Old Jul 15, 2001 | 04:50 PM
slowerthanu's Avatar
New User
Default Re: Video of my mis-shift (xjohnx)
I could not make out a thing in that video. All I heard was some 70's music probably some guy taking the T-Tops off of his Camaro.
Old Jul 15, 2001 | 04:54 PM
eurodeseo's Avatar
What's the story behind your "mis-shift"?
Old Jul 15, 2001 | 06:04 PM
xjohnx's Avatar
Default Re: Video of my mis-shift (eurodeseo)
drag strip, driving along, 3rd gear, 8400rpms, shifted into what i thought was 4th, however, it ended up being second. engine go poof, couple of bent valves, i'll have details of the damage tomorrow.
[Modified by xjohnx, 7:04 PM 7/15/2001]
Old Jul 15, 2001 | 06:55 PM
SPOON_BeIgHtEeNsEe's Avatar
hey did u notice that date july 13... it happens to be friday the 13th... did u see a BLACK cat???
Old Jul 15, 2001 | 07:09 PM
JoshRambo's Avatar
Default Re: Video of my mis-shift (00CiViC_SpecR)
that sux
i had a shitty time at the track friday as well. i guess not as bad as yours though
Old Jul 15, 2001 | 07:14 PM
itr0032's Avatar
Default Re: Video of my mis-shift (Gravity)
sorry man....
Old Jul 15, 2001 | 08:56 PM
skunk2 teg's Avatar
New User
The track i went to friday the track was shut down every 5 mins because sombodys car blew uo and they had to clean up all the fluids...
Old Jul 15, 2001 | 10:05 PM
hybrid_eg's Avatar
John that does suck man! but i guess i can call myself very lucky then..
I have never missed a second gear or any other but damn forth!!! it happened 3 times to me.. and i did not blow anything up! with my GSR motor in my hatch.. at pomona raceway i snaped an alternator belt when i did that and i did it once with my ITR motor in my hatch.. luckily everything was fine.. each time i checked compression and made sure nothing really bad happened and made sure there are no bent valves.. I think its not the driving but the way you position your hand as you are about to drop to 4th.. now i really pay attention especially when going into 4th gear even if i'm racing against someone i rather take it easy then accidentally end up blowing it up.. again sorry to hear about that..
Old Jul 15, 2001 | 10:55 PM
COREY ITR#625's Avatar
Default Re: Video of my mis-shift (hybrid_eg)
I just got my car back a few weeks ago from the same thing. I was doing about 65-70 mph and accidently went into 2nd instead of 4th. The head was fine, but every valve needed to be replaced. The compression in my cylinders was #1 160, #2 115, #3 90, and #4 was 0. You are suppose to have 180 in each cylinder. All I can tell you is that hope for the best because it is not cheap. Acura charged $780 to take the head off and put it back on and you have to pay for whatever the machine shop does to your head. I was lucky and Acura paid for the parts, but I had to pay for the labor. It ended up costing me $950 to get my car fixed. More than likely it will not be covered under warenty. The only difference between mine and your situation is that I was not racing my car. Sorry to hear about what happened and I hope it doesn't cost you as much as it did me.
gringotegra
Northwest
Nov 8, 2011 07:39 PM
Kusai.Nihonjin.Desu
Honda Motorcycles
Aug 17, 2011 10:11 AM
BABY NSX
Jan 5, 2008 02:36 PM
XShadow
Mar 1, 2004 07:16 AM
FifthGearOnline
18
Jul 10, 2003 07:10 AM
