HID Install ( a little help would be appreciated )
Old May 29, 2003 | 08:11 PM
NUTWEAVE's Avatar
Default HID Install ( a little help would be appreciated )
hi, i just recieved a Philips 6000k HID Kit from hidonline.com.
i was curious, for all of those who have HIDs on their integras, where did you mount the ballasts?
on the drivers side, there is a small (and i do mean SMALL) space to maybe lay the ballast, i don't know about mount...
and on the drivers side, there is a better amount of space, except the ABS is in the way, that and some hoses.
so, if any of you guys have some pointers, i would appreciate the help. pics would be even better. thanks.
Old May 29, 2003 | 08:17 PM
theman-dlh's Avatar
Default Re: HID Install (NUTWEAVE)
I personally can't help you out, but...
There is some good posts with picks about this if you do a search.
Old May 29, 2003 | 08:27 PM
MachAF's Avatar
Zip tie the ballasts and ignitors if you have them...
My HID set has enough cable to put the ballast up by the fire wall. I zip tied it around the clutch reseivor mount.
Passanger side is hard if you have stock air box? I don't so I got some room. I mounted them down by the ABS.
Old May 29, 2003 | 08:29 PM
Pinkertinkle's Avatar
I siliconed mine to whatever flat surface was available, ghetto style.
JBBNJ609
Dec 19, 2003 02:58 PM
kidaniel
Oct 31, 2003 12:28 PM
enrique
May 29, 2003 09:59 PM
Pat
Jun 20, 2002 09:23 AM
GSR18
Aug 26, 2001 01:22 AM
