i need help.....please....codes
i just replaced my motor in my car.....i put a ZC16 motor in it, the problem is, i also had to do a DX to SI swap on the intake and DX harness.....the problem is, i am throwing codes 1, 9, 10, and 14.....i looked the codes up, but i dont know where they are on the engine.....can someone pleas help me?!?!?!
9 is the cylinder position sensor (in an obd-1 car), probly somethingn to do with your dist. wiring. the other, i dont knwo off hte top of my head.
code 1 its oxygen content, get a new O2 sensor
code 9 CYL snesor.... u either did something wrong on the wiring or dizzy its bad....
code 10 its Inta Air Temperature... get a new one if its not either wire d wrong or have the wrong plug conected...
Code 14 its IAC.. idle air control valve... ur eacv it s either bad or u havent extended the wires yet....
neroren
Apr 29, 2010 08:26 AM
yoshi06
Mar 27, 2009 07:32 PM
FourthGenHatch
May 3, 2003 08:48 AM
