how many miles do you have on your crx / EF?
Old May 29, 2003 | 04:45 PM
whoobeedoobee's Avatar
Default how many miles do you have on your crx / EF?
Just curious.
I am looking at an EF with 140,000. Thinking about swapping the motor out after I save more cash.... and if I buy it.
Thanks.
Old May 29, 2003 | 04:47 PM
SC0TT's Avatar
151,xxx on body
40,xxx on engine??
Old May 29, 2003 | 05:15 PM
EL Vap133's Avatar
Default Re: how many miles do you have on your crx / EF? (whoobeedoobee)
When I got my CRX it had 140k miles, now it has 155k miles but I swapped a B16 in it now.
Old May 29, 2003 | 05:16 PM
efvader's Avatar
Default Re: (SC0TT)
Buy it dude these cars run forever I have 269,000 on my d16 and I drive it hard daily. I plan to do a swap in the near future though.
Old May 29, 2003 | 05:24 PM
mugenwannabe's Avatar
Default Re: (efvader)
208,xxx. the d16's run forever
Old May 29, 2003 | 05:30 PM
one slow d16's Avatar
143,xxx on my 91 crx si. I've got a d16y8 to swap in when fall gets here.
Old May 29, 2003 | 05:51 PM
7PSI CRX's Avatar
Default Re: (one slow d16)
Signature says it all.
Old May 29, 2003 | 06:02 PM
ElementMotor's Avatar
165,600
Old May 29, 2003 | 06:05 PM
Neukin's Avatar
Default Re: how many miles do you have on your crx / EF? (EF8 ownz u)
235,000 on the crx si
Old May 29, 2003 | 06:35 PM
philly-O's Avatar
Default Re: how many miles do you have on your crx / EF? (toyosupr)
both of my cars have 300,000 plus miles on the bodies, i have 80,000 on the motor in my beater. the only reason i pulled the motor was the tranny went bad and i wanted to do a mpfi swap. the d15 that i shot out had over 350,000 miles on it and ran fine. ooh, the last 100,000 miles that were put on the car were very beaten miles and only 2 oil changes in that time frame too. d series run forever!
Old May 29, 2003 | 08:48 PM
-slow ej-'s Avatar
man...d16 run forever...*word* but d15's i got 206xxx on it right now and its still running strong..i lovee it
Old May 29, 2003 | 08:55 PM
Denny317's Avatar
not sure, but should be around 190-200k now on the chasis. only ~7k on the beast motor
Old May 29, 2003 | 08:56 PM
Noahk's Avatar
Default Re: (-RsINtEg-)
95,362. The engine has about 80k on it.
Old May 29, 2003 | 08:58 PM
88ZCRX's Avatar
204xxx mi on the body. And looking its part in age. Less than 10k on the zc since its been in my car, but who knows how many in other vehicles. Still runs strong, but has every creek and rattle imaginable. My next crx/hatch is gonna have to be the most pristine one out there. I don't care if I spend 5000 on a shell, its gonna have a perfect body.
Old May 29, 2003 | 09:25 PM
skud_dusty's Avatar
Default Re: (88ZCRX)
i've been through 3 different gauge clusters...
lets just leave it at that
Old May 29, 2003 | 09:26 PM
incubus's Avatar
147xxx on body
about 47xxx on b16a
d15 was fine when pulled at 125000
Old May 30, 2003 | 05:43 AM
eness's Avatar
My vehicle speed sensor blew up at 173165. Still runs decent though. Burns about 2-3 quarts be4 an oil change though.
If you are swapping out the motor then basically look at the condition of the body. Look for any overspray or any obvious body damage. If the car looks like poop, chances are it is.
Old May 30, 2003 | 07:11 AM
Ef Whore's Avatar
Default Re: how many miles do you have on your crx / EF? (eness)
196,000....original d16a6 never opened up. Maintained really well though. My plan is drive it till it dies then swap. But it wont die.
Old May 30, 2003 | 08:13 AM
unstopabledj's Avatar
chassis =167,xxx
motor:block =100k,head=500..thats right 500!
Old May 30, 2003 | 08:27 AM
ridestrt's Avatar
Default Re: how many miles do you have on your crx / EF? (unstopabledj)
120,000 on the body, 181,000 on the guage cluster, 55,000 on the motor, 100,000 on the tranny
Old Jun 1, 2003 | 01:01 PM
CRX Si's Avatar
Default Re: how many miles do you have on your crx / EF? (NMcivicEF)
206xxx on body
106xxx on second A6
Old Jun 1, 2003 | 02:34 PM
sykotic's Avatar
201,000 - head gasket needs to be replaced but i'm swapping in less then a month... hopefully and I don't want to put money into this motor... lol
Old Jun 1, 2003 | 02:48 PM
VashTheStampede's Avatar
No tears. Only dreams, now.
ahhh... 188,000 on a D16A6... it fried oil, blew a head, and cracked a cylinder.... and yet it STILL ran... ARG!!! WHY WON'T THEY JUST EXPLODE!!! #$@#$@#@$#!!! NOOOO.
ah well.. B16 is worth the fumes of a D16.
Old Jun 1, 2003 | 02:49 PM
LoooseGSR's Avatar
Default Re: (VashTheStampede)
almost 190k hopefully do a swap this winter.
Old Jun 1, 2003 | 03:08 PM
4crx4me's Avatar
Blk '85 Si had 55,000 when I got T- boned at an intersection.
Wht/Blk Si has 172.000 miles it's in very good conditon all around,
exceot 1/4 panel rust starting to get bad.
135,000 on Blk Dx + B17 light rust.
141,000 on beater no rust.
