Toda Spec B's..........K&N oil filter
Old Jul 15, 2001 | 02:09 PM
EleanoR's Avatar
Default Toda Spec B's..........K&N oil filter
Do you guys reccoment upgrading the valve springs with the B Spec? Please include explanation of some sort if possible. Thanks.
Also, has anyone ever used or reccomend using a non-OEM oil filter? I was lookin at the K&N performance one. It is worth it or stay OEM?
Thanks in advance guys.
Mike
Old Jul 15, 2001 | 02:16 PM
Pistonhead's Avatar
New User
Default Re: Toda Spec B's..........K&N oil filter (talkie25)
TODA says that their valve springs are recommended for Type R engines, but not absolutely necessary. On a GSR, they would be necessary. I would get them because they are matched to the cams. Get titanium retainers as well. They reduce valvtrain weight and allow higher revs, more safely. You will not gain anything in oil filters. The factory one is as good as you will ever need. Synthetic fiber filters like Mobil One or Fram X2 supposedly trap more contaminants and flow more efficiently, but you will never feel it. I use a Fram X2 just because it has an anti-drainback valve, which prevents most of the oil from seeping back down into the sump, leaving oil up in the engine when starting it.
Old Jul 15, 2001 | 02:21 PM
EleanoR's Avatar
Default Re: Toda Spec B's..........K&N oil filter (ITR-01-269)
Hey i do probably expect to get the valve springs along with the Spec B's but why titanium retainers? You said because they allow for higher revs, more safely. I dont plan on making the redline more than 8400 rpms
Mike
Old Jul 15, 2001 | 02:30 PM
Pistonhead's Avatar
New User
Then they will allow the same revs, and more longevity, reliability. $240 (from Godspeed, nitrided).
Old Jul 16, 2001 | 12:55 AM
typer 00-115's Avatar
My K&N oil filter gave me ten whp! JK I just use honda filters I buy them in bulk so I always have one.
Old Jul 16, 2001 | 06:17 AM
R1020's Avatar
Default Re: Toda Spec B's..........K&N oil filter (typer 00-115)
i like the K&N filters because they have that hex nut on top, which makes it easy to install/remove.
Old Jul 16, 2001 | 06:58 AM
mafay's Avatar
If you don't plan to rev over 8400rpm, don't even bother spend the money on the specB, just get the specA. In order to get the power out from the specB, you will need to get the ecu reprogram. And since you at it, you may as well rise your rev limit to around 9200rpm at least. So to be safe, just get the TODA valve spring and the tit retainer. Don't be cheap on your valve train. It better be safe than sorry!!
Old Jul 16, 2001 | 08:05 AM
BLITZ's Avatar
Default Re: Toda Spec B's..........K&N oil filter (mafay)
Since oil filters came up, has anyone used the NAPA oil filter for the R? The NAPA store in my area has
a FRAM & NAPA oil filter cut out to show & xplain to customers how much better their oil filter
is compared to FRAM.
Old Jul 16, 2001 | 08:40 AM
VaporTrail's Avatar
New User
you should also upgrade your piston return springs when doing this swap j/k
Old Jul 17, 2001 | 01:00 AM
Default Re: Toda Spec B's..........K&N oil filter (VaporTrail)
This thread is funny! One reply is super technical the next is super basic. Back and forth back and forth it's got two different conversations going on!
Old Jul 19, 2001 | 07:05 PM
Vitt1's Avatar
Maybe this post is semi-tech, or is it semi-basic?
Does anyone know if K&N has the anti-drain back valve as well? I tried to email them but no response. I'll try calling.
Also, Castrol has a new filter which has synthetic media, and only costs ~$5. I am trying to contact them as well to see if I get any info. Anyone use those?
Old Jul 19, 2001 | 08:55 PM
IntegraR0064's Avatar
Yes, definitely get toda valve springs and tit retainers. And raise that redline!!!!
The cams are made to make their power around 9000-9200 RPM. So if you don't bring it up there, then you're wasting your money. If you don't want to raise your redline, I wouldn't even get cams at all...the ITR cams are good enough for that. The others aren't worth the cost if you're not using their power.
jordan184mc
Honda Motorcycles
Jan 9, 2013 01:46 AM
pippo
Honda Civic (2001 - 2005)
Sep 13, 2010 03:34 PM
skunk2finatic
Oct 28, 2004 10:05 PM
CW-ITR
Jun 18, 2004 03:57 PM
ep hatch
27
Apr 22, 2003 11:24 AM
