what knuckles can use SI axles?
my STD axles are shot. theres a guy selling his SI axles cheap so id like to know what knuckles i need to use them. he said dx knuckles will work??? TIA
right man thanks!! So all i need are the left/right knuckles from any of those models for my STD to use SI axles? nothing else? thanks
right and if you go with DX or SI's you can reuse your calipers and rotors if there in good enough condition. If you go with tegs or EX will need calipers and rotors b/c the brakes are almost 1'' larger
That I'm not sure of
. Seeing your axles are shot just bring one and if its a DX it should slip right in, wobble a bit and you can see the gap where it doesn't spline up. I learned the hard way the difference but never went any futher then that.
