anyone dyno aftermarket headgasket?
Old May 29, 2003 | 01:42 PM
IN2VTEC's Avatar
Default anyone dyno aftermarket headgasket?
have any of you guys dyno'ed an aftermarket headgasket...the ones that bump compression ratio up by .3-.4 pts. I've always heard the general rule was about 10% increase in power/torque for every pt....just wondered if any of you verified the gains on a dyno? I'm thinkin about getting a mugen or spoon headgasket.
Old May 29, 2003 | 01:45 PM
Chris N's Avatar
Default Re: anyone dyno aftermarket headgasket? (IN2VTEC)
You are retarding your cams 1 or 2 degrees (lost power essentially) unless you adjust your aftermarket cams (if you have any) to make up for the shorter head gasket.
So, to get the most out of the headgasket, you need to have adjustable cams; you might not see much difference at all on an otherwise stock motor.
Old May 29, 2003 | 02:11 PM
Reid's Avatar
Global Moderator
Default Re: anyone dyno aftermarket headgasket? (Chris N)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Chris N &raquo;</TD></TR><TR><TD CLASS="quote">you need to have adjustable cams</TD></TR></TABLE>
He means adjustable cam gears, in case it was not obvious.
Old May 29, 2003 | 02:52 PM
Chris N's Avatar
Default Re: anyone dyno aftermarket headgasket? (Reid)
oops. yea. that's what i mean. i'm a retard. sorry.
adjustable cam gears so you can un-retard the cams after you put on the headgasket.
sorry to confuse.
Old May 29, 2003 | 03:28 PM
IN2VTEC's Avatar
appreciate it guys...
johnny_bighood
11
Apr 29, 2009 10:14 AM
accord-h22
Feb 23, 2007 03:49 PM
Captain Save-a-Hoe
Nov 6, 2003 11:29 AM
dLo GSR-stolen-now-WRX
Apr 14, 2003 09:37 AM
AK94GSR
Aug 1, 2002 03:39 PM
