h22 in a 5th gen (I made a mistake on a previous post)
Old May 29, 2003 | 01:21 PM
92JDMSiR's Avatar
Default h22 in a 5th gen (I made a mistake on a previous post)
I posted a couple of days ago about what map sensor to use ina 4th gen with an H22. I made a mistake, I should have said in a 5th gen. another thing I should have asked was can I use the throttle body off of the f22b1 ont he H22?
Old May 29, 2003 | 03:17 PM
Nick M's Avatar
Default Re: h22 in a 5th gen (92JDMSiR)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 92JDMSiR &raquo;</TD></TR><TR><TD CLASS="quote">I posted a couple of days ago about what map sensor to use ina 4th gen with an H22. I made a mistake, I should have said in a 5th gen. another thing I should have asked was can I use the throttle body off of the f22b1 ont he H22?</TD></TR></TABLE>
use any map sensor, i think they are all the same for accords and preludes, im 99% sure
And why would you spend all that money on an h22a swap only to choke it with an f22 TB? If your going to do anything with the TB, have it bored and put a new throttle plate put in and have it matched to your IM
Old May 29, 2003 | 04:33 PM
AsiAnVenOm's Avatar
isn't the f22 and the h22 have the same size throttle body? both at 60mm?..check this out...if you can find a throttle body off of a 97 h22a...the map sensor is mounted on the throttle body...but if not...just use a vacuum hose and hook it up to the nipple of the f22's mapsensor and it works fine...
ziptie
Aug 1, 2007 09:08 AM
98savage
Apr 10, 2007 08:54 PM
Hotlude93
Nov 16, 2004 09:21 AM
