What do you guys use in your trannys?
Old May 29, 2003 | 12:07 PM
HavokB18's Avatar
Default What do you guys use in your trannys?
I use 10w-30...
Old May 29, 2003 | 12:12 PM
Targa250R's Avatar
be professional
Default Re: What do you guys use in your trannys? (HavokB18)
Using Honda MTF right now - but I've heard great things about GM Synchromesh fluid, so I may try that out the next time I drain my tranny.
If you're going to use regular 10w-30 motor oil, make sure you use natural oil and not synthetic.
Old May 29, 2003 | 12:13 PM
Spade's Avatar
Honda MTF.
Old May 29, 2003 | 12:18 PM
vtecvoodoo's Avatar
Future Texas Boy
Community Builder
Default Re: What do you guys use in your trannys? (Spade)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Spade &raquo;</TD></TR><TR><TD CLASS="quote">Honda MTF.</TD></TR></TABLE>
OnebadJdmEg6's Avatar
From: being tracked by FAGS Docking PERCENTAGES, GAYFUKS
Mobile 10w-30 works great last longer than MTF
Old May 29, 2003 | 12:26 PM
Caveman74's Avatar
Why is honda's tranny fluid thinner than regular gear oil?
Old May 29, 2003 | 12:45 PM
JDMH22HATCH's Avatar
Default Re: (Caveman74)
Honda MTF all the way. I run 10w-40 regular when I can't make it to honda, but I always change it immediately to MTF.
Old May 29, 2003 | 01:11 PM
acuracing's Avatar
Old May 29, 2003 | 01:18 PM
RacerXI's Avatar
Default Re: What do you guys use in your trannys? (acuracing)
b&g synchroshift
Old May 29, 2003 | 01:19 PM
blackANESE's Avatar
Default Re: What do you guys use in your trannys? (RacerXI)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by RacerXI &raquo;</TD></TR><TR><TD CLASS="quote">b&g synchroshift</TD></TR></TABLE>
Me too
Old May 29, 2003 | 01:21 PM
chillax's Avatar
Default Re: What do you guys use in your trannys? (blackANESE)
honda MTF
Old May 29, 2003 | 01:22 PM
adrian1281's Avatar
honda mtf
Old May 29, 2003 | 01:50 PM
EVIL Hx Coupe's Avatar
Default Re: What do you guys use in your trannys? (sparky69)
honda mtf
Old May 29, 2003 | 02:17 PM
leadfoot78's Avatar
Default Re: What do you guys use in your trannys? (EVIL Hx Coupe)
I'm using Red Line manual transmission fluid, I think it's semi synthetic or full synthetic.
Old May 29, 2003 | 02:20 PM
oldB18EF's Avatar
has this helped you at all? My 3rd gear is starting to grind a little and my friend keeps telling me to switch to that...I currently use Honda MTF.
Old May 29, 2003 | 02:21 PM
Galvatron's Avatar
BG Synchro-shift is the shizzy!!!! If not BG, I go with MTF.
Old May 29, 2003 | 02:24 PM
Galvatron's Avatar
I don't think the BG will make it any better, but I think it will help it from getting any worse. As long as you don't keep grinding (if you were).
RSZero1's Avatar
Default Re: What do you guys use in your trannys? (leadfoot78)
how's the redline fluid work out for you? Seals stay conditioned? Smoother?
Old May 29, 2003 | 03:29 PM
ken-e's Avatar
Default Re: What do you guys use in your trannys? (RSZero1)
I use mobil 1 10w30
Old May 29, 2003 | 03:35 PM
jdircksen's Avatar
Default Re: What do you guys use in your trannys? (eg6ken22)
The honda dealer told me to use 5w30. So thats what I used. Is this bad?
Old May 29, 2003 | 04:16 PM
all stock's Avatar
B-CRX
Nov 16, 2006 01:44 PM
Downz
Apr 28, 2006 02:51 PM
Ruben19
Dec 31, 2005 04:55 PM
1JDMDOMINICAN
Sep 23, 2005 12:38 PM
DjFreeze
Jan 31, 2004 08:33 AM
