Sway bars
Old May 29, 2003 | 07:55 AM
Peters1983's Avatar
Default Sway bars
I was wondering if there were any stock front sway bars that would fit my 91 civic STD hatch? I searched and found nothing. thanks
Old May 29, 2003 | 08:03 AM
tpr's Avatar
tpr
Default Re: Sway bars (Peters1983)
If the mounting holes are there any DX or SI front sway bar should work. Do your lower control arms have the mounting holes and is there two threaded hole in the underbody of the car. Go to the junkyard an look at the stock bar and find out if you have the proper mounting points.
Old May 29, 2003 | 08:07 AM
Peters1983's Avatar
Default Re: Sway bars (tpr)
I do know that the lower control arms havt the mounting holes, I will have to check on the threaded ones.
Old May 29, 2003 | 09:05 AM
91civicDXdude's Avatar
civic STD has all the mounting points for a DX/Si front sway bar. my brother has a 91 STD and just swapped a 91 CRX Si sway bar on the car. you need the sway bar and all mounting hardware. the hole are already there. the rear sway bar is a different story, requring you to get 91 CRX si lower control arms.
Old May 29, 2003 | 10:21 AM
Peters1983's Avatar
Default Re: (91civicDXdude)
Thanks for all the help, I really appreciate it.
1991ED6
Sep 29, 2012 01:53 PM
bluestd
Aug 8, 2009 08:49 AM
chadmasterc
Nov 24, 2003 11:21 AM
Kilohead36
Apr 14, 2002 04:02 PM
