Brake Fluid dripping from rear drum???
what do you guys think the problem is??? Brake fluid is dripping from the passenger side rear drum on my 89 crx si. I didn't notice it until i was driving down the freeway and the brakes decided to go completely to the floor, so i decided to look and see if i found anything. when it goes to the floor i can pump it a few times and it will go back to a semi-normal position. what do you think is wrong?
From: I told you to wait in the truck in Texas, United States
That sounds like the wheel cylinder is leaking and should be replaced or rebuilt...
I would also replace the shoes and turn the drum while it is apart..
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Red_Si »</TD></TR><TR><TD CLASS="quote">well it looks as if its dripping out of the bottom of the drum???</TD></TR></TABLE>
You need to take the cover off and find out, if its leaking from the top it will run down to the bottom.
I had a wheel cylinder leak and the **** went everywhere so I'd check it asap.
i third the wheel cylinder recommendation. my car leaked out the entire master cylinder worth of brake fluid in a matter of a few weeks (the car was just sitting).
get some new wheels clyinders and drum shoes while you are at it. it will cost about $40 per side for both (what it cost me for a honda wheel cylinder + autozone drum shoes).
oh and one thing i found is that the wheel cylinders i got from consumer auto parts had a very small bleeder screw, smaller than stock. you might want to check the size of the bleeder screw before buying a replacement wheel clyinder.
probably a wheel cylinder like the rest of them said, i had a busted one and it only cost me 16 bucks for a new one at autozone
leaking wheel cylinder is what your problem is, take off the rear wheel, pull the drum cover off and look to see, it is a little cylinder piece towards the top in between the two brake shoes.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by keithv »</TD></TR><TR><TD CLASS="quote">
oh and one thing i found is that the wheel cylinders i got from consumer auto parts had a very small bleeder screw, smaller than stock. you might want to check the size of the bleeder screw before buying a replacement wheel clyinder. </TD></TR></TABLE>
I had the exact opposite experience, the non-OEM cylinder I got from an autoparts store had a larger bleeder, I guess I got lucky.
Fluid from rear drum? it's one of three things:
1. bad wheel cylinder
2. bleeder valve not tightened/not working properly
3. loose/cracked/worn brake line
Brake Prices
Brake Prices
D16SiHatch
11
Apr 28, 2011 08:00 PM
Jose-aka-Pedro
May 18, 2006 03:25 PM
89sicivic
Mar 2, 2006 10:01 AM
