rack and pinion boot
Old May 29, 2003 | 01:57 AM
GooD moToRs's Avatar
Default rack and pinion boot
my rack and pinion boot is broken ... [ bellow ] anyone ever change this part in there car yet? ... if so it would be helpful if you can explain how to do it step by step. i have a 1 hour time limit tomorrow between school and work and thats all the time i have for the next 2 weeks. soo i wanted to do it as fast as possible and not have to worry about figureing it out. it would be a lot of help thanx
Old May 29, 2003 | 02:35 AM
h22 ef's Avatar
Default Re: rack and pinion boot (GooD moToRs)
if you have to ask how to do it, it will probably take longer than an hour. its not that hard to do, you should be able to figure it out just by looking at it
Old May 30, 2003 | 05:53 AM
eness's Avatar
When you are in there replacing the boot check your inner tie rod end and make sure there's no play in it. You can get dirt/debris in it from the ripped boot and then you need to replace that too.
With the car on the ground have someone steer the wheels back and forth while you get your hand under there onto the inner tie rod end. See if you can feel any Up & Down movement or if the actual tierod end is moving in/out. Either of these = time to get new inner tie rod.
B_Swapped93
Sep 13, 2013 07:14 PM
Bad_dude
Mar 21, 2009 02:44 PM
Integra Integra
Mar 22, 2006 06:10 PM
FrostySol
Suspension & Brakes
Feb 4, 2005 04:47 PM
Hcivic88
Aug 28, 2002 02:35 PM
