squeeky squeeks, front suspension. annoying as hell
The front suspension just creaks like hell when i'm driving, weapon R coilovers and eibach springs. Not new parts or anything, probably just worn, but i cant figure out what part might be causing it. the spring itself, the plastic boots on the top or bottom or the strut. Any clue what makes it squeek really bad? The rears are the same configuration and they're fine.
naw eibachs are good springs but im sure you know that speed racer.. anyways .. take a look at your bushings. check and see if any are really coroded or if your rubber boots filled with grease between the ball joints are still good.. on older civics the bushings tend to wear around 120-130k .. not much you can do except get new one wether it be stock or aftermarket.
This is a simple and easy trick i do for suspension noise. Motorcycle chain lube! Point and shoot to spray away unwanted squeeks! The shock bumper, coils, connecting assemblies swaybars and end links. Your ride will be smooth as silk and water proofed for the cost of a hearty Taco Bell Meal!
From: With my POS D15B2, Whereever whenever, United States
i got it on my rear too
just live with it
the car is 15 years old you shouldn't expect much better even with the suspension changed
just live with it
Is it safe if there are cracks?
I have squeeky noises too and im planning on getting new coilovers. I have eibach springs right now too....
I have no squeeks.....then again the suspension was completely rebuilt and a E.S. kit was installed....I think that all your old original joints and bushings are crying for attention.
I saw an article on CRX suspension noise on some mechanics
tech page can't recall the URL though.The front end of my '90 Si
squeakes under ouick accel/decel eration.
And the webpage said it could be crossmember bolts or
strut tower bolts. I haven't got around to doing it yet to see if those are the causes.
I found the URL:http://www.parttrackers.com/library/1/93/97/
Modified by 4crx4me at 1:41 PM 5/30/2003
I don't know if i would call a cracked spring perch "unsafe," but it's not something that i would want to drive around with. Just cause i can see the whole thing breaking off at some point and causing some major damage one way or another.
Solo: That page is in the manual on my sig
lol. Thanks for sharing tho!
Unabonger: Take another Rip mang. Naw brakes don't make the noise i'm talking about.
Nitrouz: The wheel bearings are good
jchxcrx: the "spring perch" (thanks 4 the tech term) is fine as well, it's old but stays around the spring and isn't worn through/cracked.
Snapshift: best advice yet!. works on most things
but not this.
MugenHonda: My CRX is my ferrari. Every luxury, fast and flawless.
Ef *****: I fear installing that bushing kit. What a crapload of work! how much information comes with the ES Kit?
Art: No strut bar on there but i do have a cheap ebay one available to put on there. Would it help that much in chassis noise?!
lol. Thanks for sharing tho! Unabonger: Take another Rip mang. Naw brakes don't make the noise i'm talking about.
but not this. MugenHonda: My CRX is my ferrari. Every luxury, fast and flawless.
if you hear squeeks check your upper control arms (ball joint) and the lower ball joints my did that for the longest time, replaced them ans the squeek is gone
GoodEyeSniper
Jan 8, 2008 11:16 AM
