SI Head on HF Block... Any troubles???
Old May 28, 2003 | 07:43 PM
HondaRue's Avatar
Default SI Head on HF Block... Any troubles???
I have recently swapped out the te head on my HF in favoof the 16 valve SI head. I have had a few problems with the swap but most I've been able to correct. Right now the computer is throwing the O2 sensor code and I've been told I need to adjust my ful pressure to correct the problem. The cam timing is also off by half of a tooth. Has anyone else experienced any of these problems?
Old May 28, 2003 | 08:07 PM
GSRSNATCH's Avatar
doesnt the hf have only 8 valve releifs in the pistons???
Old May 28, 2003 | 08:18 PM
HondaRue's Avatar
Default Re: SI Head on HF Block... Any troubles??? (HondaRue)
We discussed the lack of the other 8 valve reliefs being a problem but decided that the ony way to find out is to try it and that part of the swap came out just fine
Old May 28, 2003 | 08:24 PM
civisaurusrex's Avatar
which ecu are you running? if the egine's running way too rich, the o2 will put show full rich to the ecu. if the ecu sees full rich for too long, it will throw the o2 code because it thinks it's the o2's fault that it's running so rich. if you're running the si ecu, i suppose it's possible that it's running that rich, in which case decreasing your fuel pressure should solve the problem.
Old May 28, 2003 | 08:26 PM
Mires's Avatar
Default Re: gsrsnatch
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by GSRSNATCH &raquo;</TD></TR><TR><TD CLASS="quote">doesnt the hf have only 8 valve releifs in the pistons???
I was thinking that too but the car runs really good. I have driven it and it feels fine to me. He drives it about 20 each way to work and back and drives it pretty hard and no major problems yet.
Old May 28, 2003 | 08:30 PM
HondaRue's Avatar
Default Re: SI Head on HF Block... Any troubles??? (civisaurusrex)
I am using the SI ecu and I think I'm going to try a fuel pressure regulator and see what it does for me. I still want to know of any other problems anyone else may have encountered
Old May 28, 2003 | 11:26 PM
Magick211's Avatar
So the si head worked even though the hf pistons only have 8 valve reliefs?
Old May 29, 2003 | 05:46 AM
HondaRue's Avatar
Default Re: SI Head on HF Block... Any troubles??? (CivicBoyZC)
Yea... We were a little surprised too. The valve clearance is diddley-squat but so far no trouble
padoda94
Mar 25, 2013 02:32 PM
520_Motorsports
Aug 10, 2004 10:51 AM
shingles
Mar 16, 2004 11:22 AM
jdmtim
Jan 26, 2003 10:58 AM
90TegRex
Jun 11, 2002 07:53 PM
