*Suspension Guru's* Will a 90 CRX subframe and rack bolt to a 91 HB?
Old May 28, 2003 | 06:19 PM
Home Skillet's Avatar
Default *Suspension Guru's* Will a 90 CRX subframe and rack bolt to a 91 HB?
I found a nice little crack in my subframe and I have to replace it. I have a 90 CRX Si for spare parts I can use. I'm just wondering if the subframe and rack would bolt up to my 91 Civic HB.
Old May 28, 2003 | 06:40 PM
Audipwr1's Avatar
Default Re: *Suspension Guru's* Will a 90 CRX subframe and rack bolt to a 91 HB? (Home Skillet)
ive never done it before, but it I would guess no. I would assume there is a width difference between the two since the chassis are not identical just close
can always try though if you got the motor out its not a difficult job
Old May 29, 2003 | 10:52 AM
Anyone else?
Old May 29, 2003 | 01:27 PM
CRXBart's Avatar
The CRX and Civic sub frames are identical. I have done the swap. All parts are the same. All EF CRX and Civic hatch are the same.
Old May 30, 2003 | 04:53 AM
Default Re: *Suspension Guru's* Will a 90 CRX subframe and rack bolt to a 91 HB? (CRXBart)
Thank you sir.
Feli
May 26, 2010 02:11 PM
sonic47
Jun 29, 2009 10:03 AM
dem0nk1d
Sep 12, 2007 01:09 PM
ohforreal
Apr 20, 2005 08:58 PM
amh0001
Aug 26, 2004 02:01 AM
