jdm cluster wiring
Old May 28, 2003 | 05:07 PM
R91Si's Avatar
Default jdm cluster wiring
anyone know where i can get the wiring from a 91 civic si to a jdm civic sir?
Old May 28, 2003 | 06:58 PM
khcivic's Avatar
Default Re: jdm cluster wiring (R91Si)
i dont know i have a 88 hatchback and i got a jdm cluster and i found a wiring diagram and im gonna try to do it but the diagram uses a 90si wiring vs jdm wiring.so i dont know . i hope it works
Old May 28, 2003 | 08:36 PM
Rywire's Avatar
Default Re: jdm cluster wiring (khcivic)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by khcivic &raquo;</TD></TR><TR><TD CLASS="quote">i dont know i have a 88 hatchback and i got a jdm cluster and i found a wiring diagram and im gonna try to do it but the diagram uses a 90si wiring vs jdm wiring.so i dont know . i hope it works</TD></TR></TABLE>
The 90-91, and the 88-89 have different wiring. Ryan
Old May 28, 2003 | 10:05 PM
Built B16A's Avatar
From: hittin corners so hard you can taste my rims..
Default Re: jdm cluster wiring (droppedcrxsi)
LOL... mines a 89 SI.. all the diagrams ive seen.. didn't work for ****... all i can realy tell you, is match all the wires to the same color. 2 or 3 wont reach, so thats why i addapted my own harness.. but match all colors the same.
the only real stumper i had.. after wirring in my upgraded VSS... was that the oil press. and VSS wire were the same color.. if anything, follow it back to the ECU with a continuity check, and hook it up like that.. as for the turns, and dash lights.. just match the colors.. trust me, it works.
Old May 28, 2003 | 10:28 PM
Slurp56's Avatar
Default Re: jdm cluster wiring (Built B16A)
Damn Jigga, ever occur to you to extract the pins and push them into the new spots? (I.E. not cut all the wires)
Old May 28, 2003 | 10:32 PM
Built B16A's Avatar
Default Re: jdm cluster wiring (Slurp56)
i never had much luck with re-pinning.. i did what i had to do.. lol
Old May 28, 2003 | 10:37 PM
Slurp56's Avatar
nice
function over fashion. (you should see my CRX )
Old May 29, 2003 | 02:51 PM
khcivic's Avatar
yeah you cant see that if the cover is on lol
Old May 29, 2003 | 03:02 PM
EF-9SiR's Avatar
im in the same boat. i have an 88 hatch with a b16, and i have the SiR cluster. Ive been driving around with out being hooked up for some time now.
Built B16A- How did u figure out all the wires? just match the colors? how do you like the cluster? and does everything function properly?
Old May 29, 2003 | 06:40 PM
Built B16A's Avatar
Default Re: jdm cluster wiring (EF-9SiR)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EF-9SiR &raquo;</TD></TR><TR><TD CLASS="quote">Built B16A- How did u figure out all the wires? just match the colors? how do you like the cluster? and does everything function properly?</TD></TR></TABLE>
all but the oil press, and VSS were the same color.. everything else was a direct match. and everything works.. all but the door indicator.. the little green plug.. hatch, and doors dont' light up. also, the "Hot Cat." indicator.. other than that.. everything works..
later on down teh road.. once i get my car back together, after the paint job.. im thinking of getting a low fuel sender and swaping that icon, and making it low fuel indicator.. that, and getting the doors to work. no biggie though.
Old May 29, 2003 | 07:12 PM
EF-9SiR's Avatar
so the tach, speedo, fuel, signals, temp, and headlights work? thats all i really need.
Old May 29, 2003 | 07:16 PM
Built B16A's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EF-9SiR &raquo;</TD></TR><TR><TD CLASS="quote">so the tach, speedo, fuel, signals, temp, and headlights work? thats all i really need.</TD></TR></TABLE>
yes in deed... its a sorta shitty pic.. really dark, but everything works.. and amber.. gotta love that.
Old May 31, 2003 | 03:24 PM
EF-9SiR's Avatar
so, did u have to get an electronic VSS and have that wired to your ECU, then from your ecu to the cluster?
Old May 31, 2003 | 03:25 PM
Built B16A's Avatar
you got it..
Old May 31, 2003 | 04:26 PM
EF-9SiR's Avatar
you want to do it for me man? im too lazy haha. thanx for the info. i might take it to the shop that sold me the cluster, they are asking 100 bucks or something.
mr.krits
Sep 21, 2007 06:01 PM
tdo
Mar 3, 2005 08:16 AM
floyd stuart
Jul 28, 2004 06:57 AM
maximedx
Jul 28, 2003 11:46 AM
