welded diff / prodrive drag spool on street car
Old May 28, 2003 | 02:15 PM
Greyout's Avatar
Default welded diff / prodrive drag spool on street car
is this a rediculous idea, or is it ok to drive on the street with a solid differential? How tight of a radius can you turn before the car starts to hop around or whatever it does?
Old May 28, 2003 | 02:21 PM
D-Man's Avatar
Default Re: welded diff / prodrive drag spool on street car (JDM LUDE)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDM LUDE &raquo;</TD></TR><TR><TD CLASS="quote">is this a rediculous idea,</TD></TR></TABLE>
Yes,dangerous and not very friendly to axles.
Old May 28, 2003 | 03:57 PM
Jared's Avatar
Default Re: welded diff / prodrive drag spool on street car (D-Man)
I do it in my street turbo car, its not bad once you get used to it, but it is a little rough to make sharp turns. If you can handle an extreme clutch and pressure plate on the street and not complain, then you wont mind having a spool either, same amount of inconvenience.
Old May 28, 2003 | 04:00 PM
J2turbo21's Avatar
Default Re: welded diff / prodrive drag spool on street car (Jared)
What makes it so hard to turn?
Old May 28, 2003 | 04:11 PM
BoostingSnail's Avatar
Default Re: welded diff / prodrive drag spool on street car (J2turbo21)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by J2turbo21 &raquo;</TD></TR><TR><TD CLASS="quote">What makes it so hard to turn?</TD></TR></TABLE>
Its like a solid axle....one wheel will make a tighter radius than the other on a turn....this is why most people use an LSD on the street...it makes up for the radius differences where a spool cannot
Old May 28, 2003 | 06:37 PM
tony1's Avatar
Default Re: welded diff / prodrive drag spool on street car (BoostingSnail)
It's driveable, but puts alot of stress on your axles!
Old May 28, 2003 | 10:16 PM
Charles B.'s Avatar
Default Re: welded diff / prodrive drag spool on street car (tony1)
i also hear it makes it hard to parallel park...if so i don't see that inconvenience worth it on a daily driver.
Old May 28, 2003 | 10:49 PM
bottlefedb18c1's Avatar
hell i used to drive with a open DP with my turbo gsr everyday for work and everything for over 4 months with a extrem pressure plate and disk and no ps with 20 psi of air in my tires and it was fine for me i just got alittle larger on the arms and shoulders
Old May 28, 2003 | 11:15 PM
turbospool's Avatar
Default Re: (bottlefedb18c1)
im 17, turbo integra, no ps, 350mm sparco wheel,no ac, no cruise, open shorty rev hard dp, extreme pp four puck, hasport 80a drag mount, bfg's...
Old May 28, 2003 | 11:27 PM
Charles B.'s Avatar
Default Re: (turbospool)
Can you really compare no ps to a welded diff? I've never had power steering, but I can only imagine a welded diff. would make it worse. Now you guys are talking about an open DP; I think I would be able to handle that or at least an e-cutout.
Old May 28, 2003 | 11:43 PM
turbospool's Avatar
Default Re: (SuperDuperEG)
o wait, forgot the most improtant thing, Prodrive spool...
broke my godam stage I driveshaftshop.com axles...
Old Jun 2, 2003 | 08:17 AM
riceboyEFsi's Avatar
ive also never had a car w/ a/c or p/s my cars have also had act 6 puck
(act = another cracked tranny)) clutch master stage 5 (to hardcore) clutchmaster stage 4 (just perfect) w/ no problems anyways i asked my friends who builds trannys about running a welded diff and he said it is not streetable what so ever. This guy knows his **** . If u do it let me know how it turns out
Old Jun 2, 2003 | 08:34 AM
Elex's Avatar
Default Re: welded diff / prodrive drag spool on street car (riceboyEFsi)
i knew a few people who ran welded diffs on the street, but they just wound up breaking the spider gears everytime.
Old Jun 2, 2003 | 01:03 PM
turbospool's Avatar
Default Re: welded diff / prodrive drag spool on street car (BSeriesMadness)
its streetable...., but i have another tranny for street..
enzozenuni
Oct 1, 2006 04:03 PM
Sport_Injected
70
Jan 9, 2006 06:26 PM
bnut510
Sep 8, 2005 09:22 AM
SEFIxCivic
Oct 6, 2004 10:45 AM
HondaRacer32
Jan 20, 2004 11:52 AM
