question about mini me (dont mean to beat a dead horse )
Old May 28, 2003 | 01:48 PM
N20B4PSI's Avatar
Default question about mini me (dont mean to beat a dead horse )
i just picked up my 3rd ef hatch and i have a sohc zc motor in my shed that i was gona drop in it since the car burns oil. i did a search on the mini me setup but have a few questions that i wasnt realy clear on. 1st if my friend is going to give me a z6 head for free . i want to know if the head is all i need since i have all the si stuff already (i.e intake manifold, header and the ignition setup) im thinking all i would need to buy is some head studs and a new gasket to slap that head on...if i need more than that let me know... any info will be helpful
Old May 28, 2003 | 01:52 PM
4drEF's Avatar
Keyboard Humorist
Default Re: question about mini me (N20B4PSI)
The only other thing you need is a way to activate vtec and deal with the fuel map during vtec (like an Apex'i V-AFC).
Will the Z6 head bolt onto the SOHC ZC? I haven't seen many posts that discuss SOHC ZC's much less making them a mini-me.
Old May 28, 2003 | 04:42 PM
CRXTC's Avatar
yes the Z6 head will bolt on to the ZC block, and it'll give you a wack of compression. I believe the Z6 head is better due to the bigger valves and ports...but don't quote me....
Old May 28, 2003 | 05:24 PM
91civicEX's Avatar
As long as this thread is open id like to know if this will work. i am going to convert my car to obd 1 and since the y8 is obd 2 i cant use all its parts. ill be using y8 head with a z6 cam and a z6 ecu. z6 inejctors and z6 dist. so i can have the high compression y8 with all the obd1 components. am i right or is there an easier way?
Slavik89
Jun 12, 2013 11:48 AM
roterx7
21
Dec 24, 2006 08:44 PM
slowcrxsib16
Aug 20, 2006 10:36 AM
CRXSI_09
May 29, 2006 12:13 PM
EsCo_EsCo
Jun 4, 2004 05:23 AM
