*ABS Problems*
Old May 28, 2003 | 01:45 PM
joe_black's Avatar
Default *ABS Problems*
Hey Gents,
My ABS light came on the other day and i checked all the fluids ect.. It will come on in between shifts and then go off i would hear a relay or sensor clicking under the passengers side dash.. kinda like a ground or short problem. I was trying to see if i could extract a code or reset it to see if maybe that was the prob but I am not sure whare the jumper is to get the code out? If any of you know or hav had any problems let me know if this is common. I need to find out what plug it is and or what I can do to remidy this problem. Let me know what I could do...
Thanks
Joe
1997 Accord Ex Coupe
Old May 28, 2003 | 01:59 PM
Chiovnidca's Avatar
Default Re: *ABS Problems* (joe_b)
To check for codes, jump the same connector you would to check a CEL.
Old May 28, 2003 | 02:39 PM
joe_black's Avatar
Default Re: *ABS Problems* (Chiovnidca)
Thanks Bud! I am going crazy. I just want to drive this bastard off a cliff sometimes. I hope the ecu stored a code because it will come on in between shifts and it will sometimes cut out the radio and sub. I hear the relay click under the passengerside dash so maybe when i put it into mode it may just let me know it may be a faulty diode in the relay. What do you think?
-Joe
Old May 28, 2003 | 02:59 PM
Chiovnidca's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by joe_b &raquo;</TD></TR><TR><TD CLASS="quote"> What do you think?
Lets see if it has a code stored and go from there.
Old May 28, 2003 | 03:14 PM
joe_black's Avatar
LOL,
The sub is wired up to the rear taillight plug. The person who had the car before just found a *HOT* source in the plug and shuved the wire into it. That may be the problem because their was no fault in the ecu or the abs. The light just shut off when I jumped the cel plug. I might try to just undo it for the ride home and see how it acts.
-Joe
secur60
Jun 14, 2024 08:57 PM
benkei
Oct 31, 2009 10:03 AM
BoltonGSR
Dec 1, 2007 08:06 PM
joe_black
May 30, 2003 01:29 PM
roadawg
Mar 5, 2003 03:37 PM
