CV boot installation!! need assistant
Old Jul 14, 2001 | 09:56 PM
TeginRAGE's Avatar
New User
Default CV boot installation!! need assistant
Doing my CV boot today, was curious on how hard it is and what tools i'll need? Any pointers would be of great help......
Old Jul 15, 2001 | 07:24 PM
TeginRAGE's Avatar
New User
Default Re: CV boot installation!! need assistant (TeginRAGE)
Ok the cv boot installation was a pain but worked out pretty well, it seems like nobody knew how to do this replacement so i guess that not alot of ppl on this forum knew how to do it, i assume...
Old Jul 16, 2001 | 05:46 AM
TRuST's Avatar
It's really pretty easy. Just remove the axle nut and the nut below it on the opposite side. It's the nut with a pin going throught it. Lift and remove the hub assembly off the axle and use either a friend or bungee cord to hold it out of the way. From there, you can replace the outer CV boot. If you need to get the the inner boot just get a hammer and tap out the axle from the tranny to get access to the inner CV joint. While you are replacing you CV boot, make sure that you repack the CV joint with grease.
Old Jul 16, 2001 | 01:36 PM
Mr. Choi's Avatar
New User
the easiest way is to,
replace the whole axle...
Old Jul 16, 2001 | 06:41 PM
fixhondas's Avatar
Default Re: CV boot installation!! need assistant (ChoisVTEC)
what year/model??
Old Jul 17, 2001 | 06:17 AM
VTECHGSR's Avatar
New User
Default Re: CV boot installation!! need assistant (TRuST)
Are you sure? We has to replace one on a friend's civic and to replace the outer boot we had to remove the inner boot and slide the whole assembly out that way. Pain in the *** but much cheaper than paying honda 300$.
aziantegger10
Feb 6, 2010 08:23 PM
Jimster480
Jan 22, 2010 10:58 AM
oldskoolDA6
Jul 9, 2009 11:39 AM
B18CivicEH2
Mar 19, 2007 03:13 PM
Vitesse
Jul 24, 2006 10:09 AM
