Specs on 1990 SI Hatch
Old May 28, 2003 | 12:53 PM
whoobeedoobee's Avatar
Default Specs on 1990 SI Hatch
Does anybody know the specs on a stock 1990 SI Hatch?
Someone had a website in their sig that had a great site, but I didn't bookmark it.
Thanks for the help
Old May 28, 2003 | 12:55 PM
elmalouno's Avatar
Default Re: Specs on 1990 SI Hatch (whoobeedoobee)
complete specs?
buy a helms manual
Old May 28, 2003 | 01:28 PM
Perfectionist's Avatar
What specs are you looking for? I have the original sales brochure that lists some of them and a crappy Chilton's that list more, but is full of errors.
Old May 28, 2003 | 01:48 PM
Default Re: Specs on 1990 SI Hatch (Perfectionist)
curb weight
HP
Thanks
Old May 28, 2003 | 02:37 PM
DJ_SaNdOz's Avatar
108 hp I beleieve & like zero torque lol
Old May 28, 2003 | 02:49 PM
slowman's Avatar
I took way too long
Default Re: Specs on 1990 SI Hatch (DJ_SaNdOz)
Engine CRX 1990
Type CRX HF CRX CRX Si
Type: Aluminum-Alloy In-Line 4 * * *
Displacement (cc) 1493 1493 1590
Horsepower @ rpm (SAE net) 62 @ 4500 92 @ 6000 108 @ 6000
Torque (lb.-ft. @ rpm) 90 @ 2000 89 @ 4500 100 @ 5000
Compression Ratio 9.6:1 9.2:1 9.1:1
Valve Train SOHC 8-Valve SOHC 16-Valve SOHC 16-Valve
Fuel System Multi-Point Fuel Injection Dual-Point Fuel Injection Multi-Point Fuel Injection
Ignition System: Electronic, Distributor, Single Coil * * *
Drivetrain
Type: Front-Wheel Drive * * *
Manual Transmission: 5-Speed * * *
Automatic Transmission: (available) NA 4-Speed NA
Final Drive Ratio (MT/AT) 2.95/NA 3.89/3.93 4.25/NA
Body/Suspension/Chassis
Body Type: Unit Body * * *
Suspension: Front: Double Wishbone/Rear: Multi-Control Double Wishbone * * *
Stabilizer Bar (mm, front/rear) 17.0/NA 18.0/NA 18.0/15.0
Steering Type: Rack-and-Pinion * * *
Turning Diameter, Curb-to-Curb (ft.) 30.4 30.4 30.4
Dual-Diagonal Brake System Front Disc/Rear Drum Front Disc/Rear Drum 4-Wheel Disc
Wheels 13" Steel w/Center Caps 13" Steel w/Center Caps 14" Alloy
Tires: All-Season P165/70 R13 All-Season P175/70 R13 All-Season P185/60 R14 82H
Exterior Dimensions
Wheelbase (in.) 90.6 90.6 90.6
Length (in.) 148.5 148.5 148.5
Width (in.) 65.9 65.9 65.9
Height (in.) 50.1 50.1 50.1
Track (in., front/rear) 57.1/57.3 57.1/57.3 57.1/57.3
Curb Weight (lbs., MT/AT) 1967/NA 2103/2136 2174/NA
Coefficient of Drag (Cd) 0.29 0.30 0.30
Interior Dimensions
Headroom (in.) 37.0 37.0 36.7
Legroom (in.) 40.8 40.8 40.8
Shoulder Room (in.) 53.5 53.5 53.5
Hiproom (in.) 54.9 54.9 54.9
Cargo Volume (cu. ft.) 23.2 23.2 23.2
Capacities
Engine Oil with Filter (qt.) 4.2 4.2 4.2
Fuel (gal.) 10.6 11.9 11.9
Cooling System (qts., MT/AT) 5.5/NA 5.4/5.3 5.7/NA
Exterior Features
Power Sunroof *
Rear Window Wiper/Washer * *
Front Spoiler * *
Manual Door Mirrors Left Left & Right Left & Right
Dual-Tip Exhaust *
Interior Features
3-Spoke Steering Wheel * *
Adjustable Steering Column * *
Quartz Digital Clock * *
Cargo Cover * *
Adjustable Head Restraints * * *
Cargo Area Light * * *
Hatch-Open Warning Light * * *
Remote Hatch Release * * *
Remote Fuel Filler Door Release * * *
Reclining Seatbacks * * *
Tachometer * * *
Trip Odometer * * *
2-Speed/Intermittent Wipers * * *
Rear Window Defroster with Timer * * *
Driver's Footrest * * *
Coin Box * * *
3-Point Passive Restraint Seat Belt System * * *
Child Safety-Seat Anchors * * *
Exterior/Interior Colors
Tahitian Green Pearl/Black *
Rio Red/Black * *
Flint Black Metallic/Black * *
Frost White/Black *
Frost White/Blue * *
Torino Red Pearl/Black *
Celestial Blue Pearl/Black *
EPA Mileage Estimates
49-State: City/Highway (5-Speed Manual) 49/52 32/36 28/33
49-State: City/Highway (4-Speed Automatic) NA 29/34 NA
California: City/Highway (5-Speed Manual) 43/49 32/36 28/33
California: City/Highway (4-Speed Automatic) NA 29/34 NA
Old May 28, 2003 | 04:50 PM
elmalouno's Avatar
holy crap i hope u had that handy and didn't type it all out! heheh
Old May 28, 2003 | 05:40 PM
Default Re: Specs on 1990 SI Hatch (slowman si)
I appreciate the cut and paste!
Any good websites that I can reference (Not that the previous post wasn't enough)
Thanks
Old May 29, 2003 | 11:50 AM
slowman's Avatar
I took way too long
http://www.edmunds.com/used/19...Honda*
VTECengaged
Nov 28, 2006 07:04 PM
pho iz good
May 29, 2004 02:02 PM
VTC_CiViC
Sep 12, 2002 01:59 PM
WTypeRogerX
Jun 20, 2002 07:56 PM
Chengster
Mar 11, 2002 02:03 PM
