what throttle for itr intake manifold
Old May 28, 2003 | 12:25 PM
RedRex8's Avatar
Default what throttle for itr intake manifold
what throttle body should i combine to the itr/ctr intake manifold for best results? it is going on an n/a motor (b16a1), would it be better if I got the intake manifold ported and polished combined with 68mm- 72mm tb, or just stick with stock manifold with stock itr tb? how much of a difference between the two? Thanx for any help you guys couild give, i just want to go the right way all the way throw this time.
Old May 28, 2003 | 01:33 PM
SC0TT's Avatar
Use a stock ITR throttle body.
Old May 28, 2003 | 03:39 PM
xsellxoutx's Avatar
Default Re: what throttle for itr intake manifold (RedRex8)
acura TL throttle body
Old May 28, 2003 | 09:49 PM
Cm91h22a's Avatar
Default Re: what throttle for itr intake manifold (xsellxoutx)
STR 68 or 70 mm
Old May 28, 2003 | 09:52 PM
Built B16A's Avatar
From: hittin corners so hard you can taste my rims..
Default Re: what throttle for itr intake manifold (Cm91h22a)
70MM spoon... and no.. im not a sell out.. but its the ****!
Daniel-sanB1
Jun 6, 2007 10:10 PM
500hpintegra
Oct 9, 2006 02:22 AM
