Dual Port Civic Help????
Old May 28, 2003 | 11:47 AM
civicspeed77's Avatar
Default Dual Port Civic Help????
I have a 90 dual port civic and its not keeping a gas flow? Any suggestions?
Old May 28, 2003 | 11:59 AM
Perfectionist's Avatar
Default Re: Dual Port Civic Help???? (civicspeed77)
Need more detail... How did you determine "not keeping gas flow"? Do you have fuel pressure? Injector(s) not operating? Main relay good?
Old May 28, 2003 | 02:17 PM
I was cruising down the road and it shut off. I checked the and replaced the injectors, distributor, plugs /wires, fuel pump, fuel filter, and their is fuel pressure. I wonder if it might be the throttle body (TPS) or the Fuel Sending Unit.
Old May 28, 2003 | 02:54 PM
RCautoworks's Avatar
Default Re: (civicspeed77)
How bout the main relay ?
Old May 28, 2003 | 03:29 PM
Default Re: (90blackcrx)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 90blackcrx &raquo;</TD></TR><TR><TD CLASS="quote">How bout the main relay ?</TD></TR></TABLE>
No, he says there is fuel presure. But on second thought, the MR does supply the power to the injectors, but if it wasn't, that should trigger a CEL.
To the original poster.... just for grins, pull the distributor cap and check the rotor. The set screw sometimes falls out.
Old May 28, 2003 | 03:32 PM
Whats a CEL????? Oh yeah I did relace the main relay too. My car starts up but shuts off right away. I put a screwdriver in the throttle body to open up the butterflys and when I started the car, it stayed on but idled high, so when I pulled the screwdriver out it shut off again.
Old May 28, 2003 | 04:26 PM
91civicEX's Avatar
if it dies when you let it idle check the EACV. on the DPFI i believe that on the DPFI manifold it is on the right side of the manifold and has two coolant lines going to it. take it off and check if the screen is plugged up.
Old May 28, 2003 | 04:31 PM
importfan85's Avatar
Default Re: (91civicLX)
CEL = Check Engine Light
tundra2000
Jun 9, 2010 06:33 PM
urithium
Oct 4, 2009 01:19 PM
90dxb20
Oct 18, 2007 08:29 PM
crj_lll
Mar 29, 2006 04:07 PM
JDMlyfestyle
12
Oct 15, 2004 03:33 PM
