ecu problems? dizzy problems?
Old May 28, 2003 | 09:16 AM
ICeDoUt's Avatar
Default ecu problems? dizzy problems?
The vehicle description: got a 90 CRX HF swapped in b16a1 motor, used Si wireharness and wired vtec from harness made form hasport. I have a PR3 with automatic trans writtin on it(don't know if its converted to manual).
The Problem: i got no spark, engine cranks but won't run. Dizzy's got power, swapped the ignitor and coil, and still no spark. Even tried using the HF ecu to start it, that didn't work either, anyone with any help, please my car hasn't run in a long time!!!??
Old May 28, 2003 | 09:44 AM
DJ_SaNdOz's Avatar
Default Re: ecu problems? dizzy problems? (ICeDoUt)
did you have to rewire the dizzy at all? or the harness going to teh dizzy?
Old May 28, 2003 | 09:48 AM
slowpokesi's Avatar
check fuses, check grounds, make sure that you hooked the starter solenoid back up,
Old May 28, 2003 | 10:11 AM
ICeDoUt's Avatar
Default Re: ecu problems? dizzy problems? (DJ_SaNdOz)
actually yea i had to rewire the 2 wires (black and yellow is one dunno the other color) going to the dizzy, cause the great motor I got from japan had those 2 wires cut, but i did a pretty good job soldering them back together, and the dizzy is still gettin power.
Old May 28, 2003 | 10:14 AM
ICeDoUt's Avatar
Default Re: ecu problems? dizzy problems? (slowpokesi)
checked all my fuses under the dash, and went over the motor again and again for the grounds, pretty sure i got them all. and the started selonoid, whats that look like? but i am almost positive i hooked everything up
101crx
Mar 23, 2012 03:50 PM
Otownking10
Feb 27, 2010 10:44 PM
ef-hatchcrap
Feb 16, 2010 07:45 AM
16yroldekownr
13
Nov 4, 2009 04:36 PM
mkcivic
Jun 13, 2007 04:44 PM
