Head gasket for JDM H22a, bumping compression ratio
Old May 28, 2003 | 08:11 AM
GranPrix's Avatar
Default Head gasket for JDM H22a, bumping compression ratio
I'm installing Type-S pistons on my jdm h22a, since I'm bumping up the compression ratio should I go with the stock head gasket or go with a Type-S gasket if there is any? I know the gasket plays a role in the comp. ratio.
Old May 28, 2003 | 01:24 PM
juicedh22's Avatar
Default Re: Head gasket for JDM H22a, bumping compression ratio (ACCH22)
If you really want to use a head gasket to help comp. ratio, get the spoon head gasket, it raises it slightly, not much, but it says by .2 points....
h22mark
Oct 10, 2004 07:03 PM
HotWheelz
May 22, 2003 05:39 PM
Evs-One
Mar 3, 2003 01:09 AM
B18CRacer
Jan 29, 2002 11:39 AM
