crx dash in a 90civic si?
Old May 28, 2003 | 08:04 AM
cdn90civicsi's Avatar
Default crx dash in a 90civic si?
will a crx dash fit into my 90 civic si iv herd the guage pods are different sizes and what about the stero mounting and heating controls .. has anyone attempetd this swap ..... i need some advice
thanx
Old May 28, 2003 | 08:31 AM
EL Vap133's Avatar
Default Re: crx dash in a 90civic si? (cdn90civicsi)
I haven't done it myself but it myself but it has been done though...
Old May 28, 2003 | 08:33 AM
qcoffey's Avatar
Default Re: crx dash in a 90civic si? (Vap133)
My friend has done it in his '90 Si. I've just pulled the dash in a '90 CRX that will be going into my '88 DX. My friend says it is a straight forward swap. It should take less than an hour to pull your dash and install the new one.
Old May 28, 2003 | 09:07 AM
91hatchcivic's Avatar
Default Re: crx dash in a 90civic si? (qcoffey)
i had a crx dash in my 91civic, fit good, looked good too
Old May 28, 2003 | 09:13 AM
SteveeeO's Avatar
Default Re: crx dash in a 90civic si? (91hatchcivic)
so this does bolt right on? I can pick up a CRX dash for $40 at my junkyard with exchange... anyone know what tools are needed?
and to answer your questions, I think the climate control is exactly the same (CRX to Civic) and they both came with the same radio bracket.
Old May 28, 2003 | 09:22 AM
EL Vap133's Avatar
Default Re: crx dash in a 90civic si? (SteveeeO)
The climate controls from a CRX and a Civic are different....
Old May 28, 2003 | 12:07 PM
keithv's Avatar
the bracket under the radio (on the floor) doesn't line up. i just used zip ties to mount it.
this was an 88 crx si dash into an 89 civic si.
Old May 28, 2003 | 01:36 PM
litlekikr's Avatar
Default Re: crx dash in a 90civic si? (keithv)
ha, I zip tied mine to, i was like f**k it. Here's a link to a post of mine that has picts of my dash swap. It's not hard but it's tedious. Then again, i painted mine so it took a lot longer then it would normally.
https://honda-tech.com/zerothread?id=502549
Check it out.
Kumakis
Feb 16, 2012 07:15 AM
Nihilus
Apr 9, 2006 12:49 AM
Mr Furball
Aug 23, 2002 06:27 PM
jas_honda_uk
Mar 11, 2002 11:19 AM
