is there a fuse somewhere for the cig lighter in a 4th gen??
Guest
Posts: n/a
cigarette lighter isn't working, which means my "Papa John's" sign won't light up, which means i don't get paid as much..... etc etc
anyways, i checked the fuses under the dash, didn't see one labeled for "cig lighter" or whatever, is there one somewhere i'm jut not seeing?
yes the is a fuse and it is in the engine bay compartment, just look around in there, should be on the upper left side of the motor compartment...
i think on the 5th gen's it's either a 7.5 or 15.. doh i forget now! no maybe it was a 10. Damn i forget, I'm of no help lol. It's under the hood though, grab a meter and check or just start popping them out and looking for a blown one. IIRC there aren't too many normal sized fuses under there
EDIT> I know you said 4th, but I'm basing it off of what I do know from the 5th
there is 2 act. one is under the hood, its in the top row, but i think your clock/radio is on it too, so you would know if its that one. inside the car its near the top of the fuse box. there is only 2 fuse's in the row w/it.
ot: you work for pj's, huh. im the asst. mgr for one out here.
Guest
Posts: n/a
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by fastludeh22 »</TD></TR><TR><TD CLASS="quote">ot: you work for pj's, huh. im the asst. mgr for one out here.</TD></TR></TABLE>yeah, i gott aget that **** fixed, so i can get my 6%
clock works, but the cig lighter doesn't, maybe it's unplugged
which means i gott pull the console out to get to it
6%, whats that for? i think we do it different out here. as far as drivers they get $.70-1.00 per delivery. do you happen to know if its a franchise or corpret(sp) owned?
Guest
Posts: n/a
franchise, the corporation is "Perfect Delivery Inc" out of Greenville SC, drivers here get a certain rate per hr, then get additional pay based on a percent of how much money they take in that day, 5% normal, 6% if you sign is on and lit, and 7% if you take over 20 runs (orders) in one day/night. we have to report mileage to the IRS though, even though we don't actually get payed based on mileage
i think the fuse is under the dash. i had the same problem with my lighter... i keep blowing fuses, and i keep replacing that one fuse.
i bet it came unplugged. the fuse on the 5th for the lighter does the radio too, along with the clock
mines inside.... i guess the previous owner just ran a wire from the fog light fuse (which wasnt in use) directly to the cig. lighter.... go figure.
Modified by Elkins911 at 6:42 PM 5/28/2003
