i really need your help... H22 question
I need to know what ECU and what year i should be running for my 97 H22A4 that will be running in my 94 accord.....
as well do you guys know where i can pick one up?
do i need anything else for that conversion as well???
thanks
thanks
right place? im buying this from my friend whos keeping his ecu...
if i need an OBD1 ecu would any of the ecus work??? like a 92 would be the same as a 95?? is there a adapter i must get too to use the 97 engine in my 94 accord?
as well does the header for my F22 line up with the H22 block?
thanks for the help
thanks for the help
import_tuner13
Nov 12, 2011 01:03 AM
