Where to 929RR/954RR velocity stacks?
Old May 28, 2003 | 01:17 AM
JaeOne3345's Avatar
Default Where to get 929RR/954RR velocity stacks?
Hi im wondering if you Bike guys know of any companies that produce performance velocity stacks/horns besides factory pro. they have a set that runs around 220 for all four. not what im after.
thanks in advance.
Old May 28, 2003 | 11:08 AM
Shft@9GSR's Avatar
Default Re: Where to get 929RR/954RR velocity stacks? (JaeOne3345)
did you try Erion Racing? Or maybe even Honda Racing?
Old May 28, 2003 | 11:37 AM
rastropovitch
Guest
Posts: n/a
Is that a Carbed or injected bike?
Schu
Old May 28, 2003 | 02:49 PM
JaeOne3345's Avatar
Default Re: Where to get 929RR/954RR velocity stacks? (MSchu)
its fuel injected. excuse my ignorance guys. im using them for adaption to a car. i dont know much about the different companies.
i looked on factorypro and the fireblade forums with not much luck. thanks.
Old May 29, 2003 | 11:33 AM
Jeff C's Avatar
I just got a set of regular OEM ones form the Honda dealer for like $20/set.
Old May 29, 2003 | 11:55 AM
JaeOne3345's Avatar
Default Re: Where to get 929RR/954RR velocity stacks? (Jeff C)
what do they look like?
from what ive seen they are just black plastic right?and they arent equal length are they?
the factory pro are metal and equal length. made about 2-3HP difference on their bike dybo charts.hmm.
Old May 29, 2003 | 12:44 PM
Jeff C's Avatar
The two outside ones are about 1" shorter than the inside two. The factory pro ones might not be long enough. How long of a system (mani flange to stack opening) are you shooting for?
Old May 29, 2003 | 12:46 PM
JaeOne3345's Avatar
i havent got into tuning harmonics and stuff like that yet.
what i do wonder is if the 954 TB's are externally the same as the 929. i had a friend measure the diameter of the throttle bodies where you slip the rubber manifold boot on and its 1 and 15/16th inches. im hopn the 954 is the same. cuz then ill get the 954 and my "manifold" will still be ok.
Old May 29, 2003 | 12:56 PM
Jeff C's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JaeOne3345 &raquo;</TD></TR><TR><TD CLASS="quote">i havent got into tuning harmonics and stuff like that yet</TD></TR></TABLE>
Your eyes will go crossed. I kinda have an idea of what I would like to do.
I have an extra b16 mani that I was going to use the flange from and then I was going to make my own runners cause the b16 runners dont quit line up. I should have got a set of GSXR 750 itbs cause they are a tad larger and I believe that they are individual, not a unit.
Old May 30, 2003 | 07:40 PM
Jeff C's Avatar
OEM stacks:
Old May 30, 2003 | 10:16 PM
JaeOne3345's Avatar
goddamn those are long. thanks. i heard they dont seal right without the box. is that true? how tall is the tallest stack?
Old Jun 1, 2003 | 06:37 AM
Jeff C's Avatar
The tallest ones are 5". As far as not sealing w/o the box, I kinda get the impression after messing around with them, but I dont that thats anything a little RTV couldnt fix.
Old Jun 1, 2003 | 09:44 AM
tonydatyga's Avatar
RTV fixes a lot of things. I'd give grey assembly adhesive the nod before rtv first. Shouldn't make a difference though. The grey stuff just seems to act better as a structural brace where rtv is sealant first. I'm sure that made no sense.
WhiteBB2
Honda Motorcycles
10
Jul 28, 2009 06:36 AM
Jorsher
Honda Motorcycles
24
Oct 24, 2005 11:59 AM
thehatchninja
Honda Motorcycles
Mar 2, 2005 09:39 AM
fluke702
Honda Motorcycles
Nov 23, 2002 12:27 AM
