Skunk 2 stage III cams?
Old May 27, 2003 | 09:30 PM
jdm pwr's Avatar
Default Skunk 2 stage III cams?
I am looking for a set of skunk 2 stage 3 cams. I have stage 2's now but I am looking to go a little more wilder.
Any recommendations on what shop to purchase from?
Opinions are welcome.
Thanks
Old May 27, 2003 | 10:14 PM
Thawj's Avatar
Default Re: Skunk 2 stage III cams? (jdm pwr)
Call up rbh motorsports. 1-888-648-9836 toll free. if that doesn't work try 612-866-8197 http://www.rbhonda.com Ask for Eric after 1pm-11pm.....
Old May 27, 2003 | 11:54 PM
s2k420's Avatar
How's the idle on the stage 2's in your car? What other mods do you have in your car?
Old May 28, 2003 | 06:39 AM
jdm pwr's Avatar
Default Re: Skunk 2 stage III cams? (JDmMugeNItR)
Sometimes I have trouble starting her in hot weather, this is solved turning the computer, fuel pump and everything on for a few seconds before actually trying to crank her up. Again this happens only in extremely hot, humid weather. But when the engine is warm you would not be able to tell that i even have stage II's. It idles perfect. Now I only have them retarded and advanced 1 and 2 degrees. Nothing real wild but this is what they recommended when I called. Otherwise I have a comptech intake and header, test pipe, stock exhaust, jun valvetrain and skunk 2 cams. That is mostly all the engine work. I also have ATS FD and between that and the computer I can really rev high in first gear and get there quickly, with mainly the purpose of shifting to 2nd and being in peak power band (6800-7100) rmps.
I lso do not have a hondata which is actually what I am looking for too, always so much to do in so little time.
I hope this helps. I will try to go in more detail on lunch break
Old May 28, 2003 | 07:35 AM
andrewasf77's Avatar
no bottom end work. isnt higher compression necessary for that aggressive of a cam?
Old May 28, 2003 | 08:15 AM
OBDI JEDI's Avatar
any numbers ? have you dynoed your car yet?
Old May 28, 2003 | 03:43 PM
jdm pwr's Avatar
Default Re: Skunk 2 stage III cams? (OBDI JEDI)
no numbers yet still working on getting to a dyno. we did run a 13.89 at 102 in the 1/4. I think those miles per hour are right but not sure, but the time is accurate. This was 7 months ago with no tuning or vafc. I am trying to get back I will try and keep you guys posted.
Old May 28, 2003 | 03:48 PM
vtecvoodoo's Avatar
Future Texas Boy
so your II`s haven`t even been tuned yet, but you want 3`s? lol
You NEED Hondata first.
Old May 28, 2003 | 06:31 PM
JDM_EK161's Avatar
I wouldn't go with stage 3. My friend blow up 2 motors with them. My buddy jerry said u need a high compression or custom piston to make them run right. I have stage 2 in my itr motor with value train and they work fine.
Just my 2 cents
vitalik
Sep 12, 2006 06:02 PM
an2ny888
Jan 23, 2005 06:48 PM
Jdmbsixteen
Aug 17, 2003 07:53 PM
SymphonyX
Mar 26, 2003 09:26 PM
LX4SI2NV
Jan 21, 2003 02:09 PM
