jcwitney pipes: how many of what for b16 ef...
i want to boost my ef b16, and just want to get the bent pipes from jcwitney and weld them myself. If someone here has done this, or would measure there pipes from there turbo kit that would be awsome
heres the link: http://www.jcwhitney.com/produ...=jcw2
any help would be great, thanks in advance.
. heres the link: http://www.jcwhitney.com/produ...=jcw2
I got two 180 degree bends, a 90 degree bend and a big J-bend. You have to cut it all up and do a bit of welding but that should be all you need for piping from the turbo to Intercooler to the throttle body.
It depends on how much power you are going to be pushing to know what diameter you need. Over 400 and you should go with 2 1/2. Anything less, 2 or 2 1/4 would be fine.
this link shoudl help too-
http://www.cse.uconn.edu/~yele....html
3 u bends with the long legs and an L bend. add another u bend with short legs if your compressor outlet faces up. you might need something else depending on what your going to do for the air inlet for the compressor.
ALLmotorCRX
Feb 27, 2003 10:14 PM
for being much cheaper than buying premade pipes.
