JDM Shift Boot - Does yours stretch this much?
Hey guys,
I installed a JDM Shifboot on my GS-R shifter. I'm noticing the boot to be stretching a bit in second gear, or in fifth or in third. Is this normal? My GS-R boot was not like this. Does it have to break it in? Or is the GS-R shifter heigher than the ITR shifter? Here are some pics:
In second gear:
and in third gear
I think this one is in forth gear:
Is the GSR shifter the same as the ITR shifter? Someone please advise.
Thanks in advance.
In second gear:
and in third gear
Thanks in advance.
Third looks fine. It looks like its just a little stretched. Or maybe its just the camera reflecting off your clothes.
PS. it looks like to change clothes pretty fast.
ya, thats what I'm thinking... thanks.
So anyone know for sure if the ITR Shifter is in fact shorter or the same height as the GSR?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Erik95LS »</TD></TR><TR><TD CLASS="quote">if I remember right the type-R shifter is just barely shorter. Someone correct me if I am mistaken.
by the way nice wind suit.
No.
You have to push the ring down the shifter. It should show a little of the shift rod.
</TD></TR></TABLE>No.
might be backwards.
edit: before we get flammers, saying its not possible, it is.
the hole is made to go more toward the ebrake. i know cause I replaced mine with one and had to turn it the other way.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 01-1293 »</TD></TR><TR><TD CLASS="quote">whats the red button for.......nawz yo?........eject seat?</TD></TR></TABLE>
dude, i think that's a shift light
I think it's his alarm LED.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Type-Rare#1248 »</TD></TR><TR><TD CLASS="quote">
dude, i think that's a shift light</TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ITR#132 »</TD></TR><TR><TD CLASS="quote">
No.
You have to push the ring down the shifter. It should show a little of the shift rod.</TD></TR></TABLE>
No.
The leather **** clips into the boot, there is no ring to push down, and if you did it would just expose the black clips on the ****.
No.
No.
yeah mine did the same thing, got mine brand new from inlinefour.com
it will be ok
i pushed the top of my plastic piece down and put a zip tie under it so it won't move.
it will be ok
yes, this button is an eject button
. In the event I loose control at high speeds, I get thrown out of the moonroof.
No.
The ring clips on the ****..you CAN'T push it down. I screwed the **** on so hard that its not even possible to remove it.
No.
hahaaaaa
members only didnt make jumpsuits - they were famous for the french collar jackets with obscene amounts of zippers.
that warmup suit is still the hotness
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Hate »</TD></TR><TR><TD CLASS="quote">lol...nice windbreaker jumpsuit....members only?</TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by majeed11 »</TD></TR><TR><TD CLASS="quote">
The ring clips on the ****..you CAN'T push it down. I screwed the **** on so hard that its not even possible to remove it.</TD></TR></TABLE>
U.S. 97-98 shift **** does not mate to JDM shift boot (You can make it clip on, but than you will start a thread and ask why the shift boot is stretched). JDM red-stitched shift boot does not clip to that shift ****. Its suppose to show a little of the shift lever. (Thats the reason the shift lever is chrome on 00/01 U.S. ITRs and black on 97/98 U.S. ITRs)
nice OUTfIT
nice OUTfIT
You cannot use the JDM shift boot with the stock 97-98 USDM shift *****. You need to get a new **** that does not have the clips...
