just installed H22 in4th gen for a friend, need help finding a map sensor
I just put in a 94 JDM H22 in my friends 94 accord. the f22 had the map sensor on the TB, the H22 has it on the firewall. does anybody know what sensor i can use for this motor. what has everybody been using on there swaps??
I was wondering.....What did you have to do to swap the H22A into the 4th gen Accord? Did you use the F22 harness, tranny, axles??? Any and all info will be greatly appreciated. Sorry, I'm a newbie
yes you can use your accord map , no problem
to the other guy
welcome to honda tech .. go ahead and read the accord forum rules and take a few mins. to learn the site and the search button. its up top. just type in h22, youll be more then full of links then
also try Accordinglydone.com , has a lot of tech and good info
good luck
to the other guy
good luck
for the h22 the only difference is the 4 wires used for the vtec hook up...the tranny should be swapped...true the f22 has longer gears but its worth it to trade out trannys cause the power difference...and use the accord axles because they are longer than the lude ones and will ast longer<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TRUSE-R »</TD></TR><TR><TD CLASS="quote">I was wondering.....What did you have to do to swap the H22A into the 4th gen Accord? Did you use the F22 harness, tranny, axles??? Any and all info will be greatly appreciated. Sorry, I'm a newbie</TD></TR></TABLE>
ricekiller1
Apr 14, 2004 05:52 PM
